  1. Hi Cats,
    I need to find a string in a input.txt file
    Current Playback Device ID=2A99FA92-E624-4650-A032-DA719D9B03D5
    and replace it with:
    Current Playback Device ID=721D0FD1-DD46-11d0-8AAC-00A0C91D299F
    BUT consider that the replace have to be also in the case that the original string - in this case Current Playback Device ID=2A99FA92-E624-4650-A032-DA719D9B03D5 - contains different chatacters
    for example Current Playback Device ID=AAAAAAAA-E624-AAAA-A032-AAAAAAAAAAAA
    How can I do?
    thanks
  2. Member Cornucopia's Avatar
    Strictly speaking, you cannot.
    But if I am correctly reading between the lines, you need to use the LEN() - length, and MID() - middle position, string functions.
    Aug 2010
    San Francisco, California
    Use regex. Search:
    Current Playback Device ID=[0-9A-F]{8}-E624-[0-9A-F]{4}-A032-[0-9A-F]{12}
    Replace:
  4. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    You can also use CMD's findstr which allows wild cards, place holders and many options. This can be used in a batch file as well for automating replacement.
