Hi.
Have this problem that I can't figure out. When the recorded sound peaks over the maximum sound limit, the playback throws out a very loud pop/click sound. That doesn't happens when using only the internal mic on camera.
I know that the obvious solution is to simply reduce the mic sensitivity. I would like to know if there is other methods, so I can use normal volume for the recordings.
Also, for those files that is already recorded (MKV full HD), is there any method for reducing the pop/clicks when converting to h264 (using Avidemux or Handbrake).
Results 1 to 1 of 1
Uncompressed AVI Audio in FFDSHOW Pops/Clicks in my Recorded AVI's - Help!!
By mdexter in forum AudioReplies: 21Last Post: 11th Jan 2015, 12:03 -
Audio pops and clicks with pot player
By G-hat in forum Software PlayingReplies: 1Last Post: 5th May 2014, 04:28 -
External Mic for Panasonic HDC-SD1 camcorder
By CJLeslie21 in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2013, 20:12 -
External Mic for Panasonic HDC-SDT750 Camcorder
By glenpinn in forum AudioReplies: 6Last Post: 14th Oct 2012, 05:28 -
Using wireless mic with shotgun mic on Canon HF G10
By jimleben in forum AudioReplies: 5Last Post: 23rd Jan 2012, 21:11
