    Sep 2014
    Rome
    hi
    i create a project and a sequence
    if i import a video and drag in the time line i got a warning about the clip doesn't match the sequence
    ok
    i have 2 option keep settings or change sequence setting
    now
    if i select a piece/clip in the source video , and click insert or overwrite , premiere doesn't warn me
    how can i fix it ?
    i have my clip selected in the source vide in the time line
    do i have only scale to frame and set to frame option to fix it ?
    or can i adapt the sequence to my clip taken from the video source
    thanks
  2. Member Cornucopia's Avatar
    Choices:
    1. Pre-process your clips so they'll match your intended sequence ahead of time (using AVISynth, ffmpeg, Virtualdub, etc).
    2. Let Premiere "interpret" your clips (properly) and then stretch/shrink and velocity control the FR, etc. to make it match.
    3. Let Premiere "interpret" your clips, but cheat and set it to interpret improperly so it tries to do the stretch/shrink for you (may or may not work right).
    4. Open your clip directly into Premiere, prior to making a sequence (using something like File:Open), or by finding the clip in explorer and right-clicking "Open With...(Premiere)". Premiere should conform the sequence automatically to match the clip (obviously only works for 1 clip format at a time).
    Have you tried just playing with it and seeing which one works better for you?
    Sep 2014
    Rome
    Choices:
    Hi Scott
    2) about
    what do you mean ?
    insert video clip for source and effect control ->motion->scale?
    about 3)
    honestly i don 't understand
    thanks
  4. Dragging a clip into a blank timeline or the new-item icon will create a sequence that matches the clip's properties.
    Any clips you later add that do not match can be changed by right-clicking on the clip ond choosing sclae to frame size or set to frame size (I prefer using "set" because it holds quality better in resizing.) You can also choose multiple clips in the timeline and it works as well.
    But really, the questions you are asking here are very basic stuff. It implies you are either to timid to experiment or too shy to look through the online help. Both would serve you well.
    Sep 2014
    Rome
    hi
    how can i fix it ?
    i'm asking alternative way to do it
    and yes i search on youtube , i bought some video tutorial
    i guess vegas it's more easy , i should use it
  6. Originally Posted by rama View Post
    how can i fix it ?
    There is an item for that under general settings -- but it seems to work only with the first clip in a sequence as you've noted.
    (During editing, I wouldn't want it popping up all the time -- but that's not your question.)
    Sep 2014
    Rome
    how can i fix it ?
    hi
    you know it's hard try to learn a program seeing my native language is not english
    and most of the tutorials free and paid are in english
    for example i' was looking yesterday for a while , a shortcut that let me slip/cut like the razor tool a clip where i have set markers or mark in & out
    i haven't found it
    maybe there is no such shortcut , and i have to use always the razor tool
    control +k work for markers
    but not for mark in and out
  8. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Vegas Pro is much more straightforward to comprehend.
    Adobe Software has always been bloated and convoluted, in my opinion. Maybe I'm not smart enough, I guess.
