hi
i tried to create a project in premiere cc 2015, import a video and edit the audio -> edit clip in audition
audition start to create Audio Extracted wav around my hard disk, i have 4 hard disks
is there to let premiere or audition to keep these files in a folder ?
thanks
	Adobe Audition create WAV file in same folder as original video file
	When you choose Edit/Edit in Adobe Audition a dialogue box opens that shows you the path. If you hit the browse button next to the path you can change it.
	Okay, I see. I always export as a sequence (even if it's a single clip.) You are correct, exporting as a clip does not give you that choice.
	hi
 so if i export the sequence i can select the folder to store all these files
 http://www.premiumbeat.com/blog/premiere-to-audition/
 thanks
	Put the clip in the timeline.
 Set in and out marks around the section you want to export
 Select Edit/Edit in Adobe Audition/Sequence
 Then this pops up:
 [Attachment 36373 - Click to enlarge]
  How to Edit Lots of Small Sections from Blu-Ray Movie (Like DVDRemake)By lind777 in forum Authoring (Blu-ray)Replies: 6Last Post: 7th Jan 2016, 10:41
  Removing bassy noise from audio clip with Adobe AuditionBy sheilanagig in forum AudioReplies: 1Last Post: 31st Mar 2014, 17:08
  AVIsynth -- how do I add an audio wav to a video only clip.. [SOLVED]By vhelp in forum EditingReplies: 7Last Post: 19th Nov 2013, 06:27
  No Audio on exported clip from speeded up footage in Premiere.By kestifer in forum Newbie / General discussionsReplies: 6Last Post: 10th Jun 2012, 18:27
  Loading 5.1 wav in PPro or Soundbooth, side channels missing? (Audition OK)By Asterra in forum AudioReplies: 0Last Post: 20th Apr 2012, 01:11
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
