Hello,
I need your help please.
How can I change the chroma subsampling from 4:2:2 to 4:2:0 on this file?
I donīt need to change anything else
I remember doing something similar with ffmpeg a long time ago, but I cannot remember the syntax.
Thanks for your help!!
Format : BDAV
Format/Info : Blu-ray Video
File size : 26.9 GiB
Duration : 2h 27mn
Overall bit rate : 26.1 Mbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High 4:2:2@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : 27
Duration : 2h 27mn
Bit rate mode : Constant
Bit rate : 24.5 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:2
Bit depth : 8 bits
Scan type : MBAFF
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.394
Stream size : 25.4 GiB (95%)
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Menu ID : 1 (0x1)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Mode : Dual mono
Codec ID : 4
Duration : 2h 27mn
Bit rate : 384 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : 79ms
Stream size : 406 MiB (1%)
Language : English
Results 1 to 13 of 13
That's a very odd piece of video you've got there. If it were truly consumer BDAV, it should only be 4:2:0.
But there could be some XDCAM-like camcorders that might record to BD, maybe this is one of those. But those are mainly MPEG2, not AVC.
And MP2 audio?
While it might be theoretically possible to maintain the luminance channel unharmed, what you're doing in the chrominance channels basically amounts to resizing the vertical in 1/2, and any time you resize you have to re-encode.
So re-encode the whole thing (audio and video) to something that is much more modern consumer-friendly.
I'm on my phone now so can't give you an ffmpeg script though I know it's possible (I would use ffmbc & cliptoolz, IIRC).
Scott -
Thanks a lot for your reply.
Actually the original video is AVC
Format : MPEG-TS
File size : 28.8 GiB
Duration : 2h 27mn
Overall bit rate : 27.9 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Codec ID : 27
Duration : 2h 27mn
Color space : YUV
Bit depth : 8 bits
Scan type : MBAFF
Stream size : 24.6 GiB (85%)
Audio #1
Menu ID : 1 (0x1)
Format : MPEG Audio
Mode : Dual mono
Codec ID : 3
Duration : 2h 27mn
Bit rate : 384 Kbps
Delay relative to video : 12ms
Language : English
Language, more info : Clean effects
Audio #2
Menu ID : 1 (0x1)
Format : Dolby E
Mode : 20
Format settings, Endianness : Little
Muxing mode : AES3
Codec ID : 6
Duration : 2h 27mn
Bit rate : 2 304 Kbps
Bit depth : 20 bits
Stream size : 2.38 GiB (8%)
Language : English
So I somehow managed to convert it to AVCHD but I suppose I can get the original file.
And then reencode or whatever needs to be done to change the chrome subsampling to consumer specs 4:2:0
So I can later use an authoring program to add chapters and menues and finally burn to BD-R
Thanks again.
That ffmpeg script would be wonderful, when you can. Thanks! -
The syntax for the 422=>420 part requires the "interlaced scaling" flag, because the chroma channels are being scaled and it must be done in an interlaced fashion, otherwise you will get chroma artifacts
-vf scale=w=-1:h=-1:interl=1 ...... means don't scale the dimensions, but do scaling operations in an interlaced fashion
-pix_fmt yuv420p ..... means YUV 4:2:0
The rest of the other arguments depend on what you're trying to do exactly, what target, what settings, what device, what restrictions (e.g .bitrates), what scenario etc.. -
Oops I missed this
Was this for BD ? Authored BD ?
If so, you should plan ahead in terms of chapters , to tell the encoder to set IDR (keyframes) at the chapter points. Otherwise the seekpoints might be slightly "off". You would do that with a qp file. FFMpeg libx264 doesn't support qpfile, you would have to use x264 CLI . -
Thanks a lot.
Sorry, but I do not understand most of what you wrote. I am a newbie.
I have a TS file of a rock concert but itīs in 4:2:2.
So I cannot run it thru TMPGENC to add chapters, etc.
How do I convert this TS 4:2:2 file to a TS 4:2:0, if possible without changing anything else so the synthax and process are as simple as possible?
Thanks again -
Which TMPGEnc ? Is this tmpgenc authoring works or mastering works ? Won't mastering works convert it to 4:2:0 for BD?
You want to make it proper for BD specs the first time around, otherwise you unnecessarily lose quality if the program re-encodes it again to comply with BD specs. Or maybe you don't care about that ?
If you don't know what is going on or what it's doing in tmpgenc, maybe another option is to use a temporary lossless intermediate converted to 4:2:0 and use that as input and let the program re-encode it with the proper chapters / keyframes ? The problem is a lossless intermediate requires lots of HDD space. Can the TMPGEnc version you're using encode video ? -
Iīve got both. I cannot find an option in Mastering Works that converts to 4:2:0
Maybe if I run it and choose BD as output it will change the chrome from 4:2:2 to 4:2:0
Iīve got plenty of drive space.
I think ffmpeg should work because I once did it with a similar 422 file. But I canīt find the correct synthax, I should have saved it more carefully for future use.
Thanks again -
If you choose a "BD" setting it should convert it for you to 4:2:0 . 4:2:2 is non compliant for BD
Doesn't authoring works encode non compliant assets as well ? When you're setting chapters, it should be done during/along with the encoding, otherwise you might get parts from the last scene when you navigate
The switches I listed above convert to 4:2:0 in ffmpeg, with interlaced scaling (since your file is interlaced, you should use this) , but all the other commands depend on what you are doing -
Nope. Outputs compliant video for the output format chosen. If the video isn't compliant for that format, TAW5 re-encodes. If the input is already format compliant, it passes thru unaltered. If the input is format compliant and cuts/joins are made, it smart renders only the cut to meet compliance.
TMPGenc Smart Renderer can work with compliant and non-compliant video. However, if you ask for BluRay, DVD, etc., it will hold strictly to the format's requirements and re-encode non-compliant input. It will smart-render non-compliant input if the specified output is the same format as the input (e.g, a 250-frame GOP mp4 will be smart-rendered only on the cut GOP's if you specify the same output format. If you input 250-GOP video and ask for BluRay, it will re-encode for compliant BD).- My sister Ann's brother -
This is what I meant - ie. does it have the ability to encode, not just author. Most consumer level authoring programs do this. So you should be able to import directly and it should encode the non compliant assets to BD spec . That would be the easiest way
If you do it without planning or in another program, the chapter points might not match the proper points in the video bitstream and chapter navigation might be off -
Yes. TAW5 accepts a whole bunch of input formats including lossless (if you have the codec installed) and it can encode or re-encode noncompliant input, as well as smart-render compliant input. It can use MPEG or its x264 encoder. But its output must be specified as one of AVCHD (for HDD / Memory, DVD, or Progressive), Blu-ray (BDMV), or DVD (DVD-Video). In other words, you can't use it to encode 250-frame GOP's as mp4 with 4:2:2 color. It's picky about output specs, such as colorspace and audio. http://tmpgenc.pegasys-inc.com/en/product/taw5_spec.html . For additional output formats/containers, try Mastering Works.
Why is chroma subsampling not classed as compression?
By kieranjol in forum Video ConversionReplies: 28Last Post: 17th May 2015, 16:22 -
How to play file with chroma subsampling 4.2.2?
By thinredline in forum Software PlayingReplies: 18Last Post: 30th Dec 2014, 15:55 -
FFMPEG chroma subsampling catproblem
By marcorocchini in forum Newbie / General discussionsReplies: 10Last Post: 25th Apr 2014, 04:42 -
How to play this file? (4:2:2 chroma subsampling H.264)
By kasda in forum Software PlayingReplies: 7Last Post: 18th May 2013, 06:16 -
Transcoding w/Procoder 3 Chroma Subsampling (lines in the color red)
By Sullah in forum Video ConversionReplies: 0Last Post: 21st Jul 2011, 13:30
