I had HD 16:9 footage (top field first) which I edited and then converted to mpeg2 (top field first) at around 4500 rate. I put this file through tmpgenc DVD authoring and it recognised and set the top field first.
When I play the resulting DVD on a player/TV, the picture looks ok, panning shots are ok. However, whenever there is fast movement the pic stutters or judders. For example, a person sitting still on a chair moves his hands, the picture stays fairly stable but the hands start to stutter.
I would have thought if field order was wrong then the whole pic would stutter including the panning shots. In any case footage was top field and I have kept it that way all the way through.
Results 1 to 10 of 10
Using American rates here, but the same would apply to 25Hz/50Hz.
Possibly the pans were shot at 1/30 shutter while the interview-type footage was 1/60. "Wrong" field order during the 1/30 shots won't stutter, because both fields would be from the same moment in time. -
Original footage was HD 1980x1080 PAL 50i frameserved to mpeg encoder.
I did another encode and this time swapped the field flag and it made no difference. -
Please post some short sample showing movement, as was suggested earlier.
What I found was that if I encode the mpeg2 file using the very very best setting (very slow) then there is less of this stutter, though not totally eliminated.
So I suspect that the stuttering was a result of not enough passes and poor motion detection.
Will have to look for an alternative mpeg2 encoder. -
1080i converted to 576i properly will not lose any motion smoothness, even at low bitrates. You've obviously done something wrong but nobody can give you concreted advice until you've provided a sample of your source -- since it appears to be somewhat unusual. And posting a sample of your converted video will give clues to what you did wrong.
I would have posted a sample but the footage contains people who would not consent to me posting it to public.
But encoding again using the best performance (more passes) has reduced the problem. So I would say it was the encoding process that was at fault. -
Unlikely that it was the encoding process. Very unlikely.
At least provide the details of how you are frameserving. A far more common culprit is serving frames out of order e.g. your decoder is probably messing up AVCHD source decoding (I'm assuming that's what your source was)
Movement from two drawings
By peterws in forum EditingReplies: 3Last Post: 7th Jun 2013, 17:57 -
Crop out movement?
By SignedupGuest in forum EditingReplies: 8Last Post: 17th Nov 2012, 23:03 -
Movement tracking while decoding
By mrjocke in forum ProgrammingReplies: 4Last Post: 5th Jan 2012, 07:48 -
Stuttering video when converting with dvd flick
By Ze Tomes in forum Video ConversionReplies: 13Last Post: 15th Dec 2011, 12:15 -
Flicker / movement on Authored DVD (Architect 4.5 pro).
By Compo in forum Authoring (DVD)Replies: 4Last Post: 25th Jun 2011, 12:59
