i recently bought myself a raspberry pi 3b and installed openelec { amber skin with plexbmc }
i get a "cache filled before reaching required amount " and the video starts to stutter after a minute .
it happens to some 720p files and all of my 1080p files { they are usually around 10gigs each }
some of my 720p videos play flawlessly , buffering takes only seconds.
ive tried to use handbrake to lower the resolution but the movies come out lower quality { all i did was lower the width to 1280 }
ive been searching web but i cant find no up to date tutorial on how to use handbrake.
i would like to know what is the best way to convert these videos so that they will stream excellently on plexbmc ?
what are the best settings ?
You may not need to convert. There's a hack that increases the read-ahead buffer size. That may fix the problem. See #7:
http://www.htpcbeginner.com/raspberry-pi-openelec-tweaks/Last edited by jagabo; 1st Apr 2016 at 08:20.
You can probably do that without re-encoding too. It's just a matter of moving header and keyframe information to the start of the file rather than the end. That can be done with the "-movflags faststart" option in ffmpeg. A command like:
Code:ffmpeg -i source.mp4 -vcodec copy -acodec copy -movflags faststart output.mp4
Avidemux: How to automatically convert AC3 to AAC of MKVs using script
By davidbgeek in forum Video ConversionReplies: 3Last Post: 15th Feb 2016, 00:31 -
Roku quit streaming Plex
By skipper49 in forum Newbie / General discussionsReplies: 2Last Post: 4th Dec 2014, 13:50 -
Trying to convert multiple mkvs to avi to play on divx dvd player?
By ericc54321 in forum Video ConversionReplies: 6Last Post: 23rd Mar 2014, 23:57 -
Perplexed by plex
By yoda313 in forum Video Streaming DownloadingReplies: 3Last Post: 21st Dec 2013, 13:44 -
Convert DVD ISOs to h.264 MKVs ?
By DButabi6 in forum DVD RippingReplies: 2Last Post: 4th May 2011, 00:27
