i upscaled a video and i noticed that when there a scene that the video goes in a vertical or horizontal way it lags
dont know how else to explain this
in the original it just goes smoothly after encoding with x265 in megui it happends
v = LWLibavVideoSource("d:\4.mp4", fpsnum=30000, fpsden=1001, format="YUV420P8")
a = LWLibavAudioSource("d:\4.mp4")
AudioDub(a,v)
ConvertToYV12()
ColorMatrix(mode="Rec.601->Rec.709")
FastLineDarkenMod()
Spline36Resize(720,480)
ColorYUV(cont_u=10, cont_v=10)
nnedi3_rpow2(2, cshift="Spline36Resize", fwidth=1280, fheight=720)
aWarpSharp(depth=15.0)
sharpen(0.3)
x265 is pretty hard to decode in real time, compared to videos encoded with x264 or XviD. So when the entire video moves, I guess that is too much for your player to handle. Usually calm scenes are much simpler and easier to decode. May want to watch with MPC-HC and LAV Video filters, to help offload processing on to your GPU.
If you feel the need to upscale for better viewing
Why not use h264
There is no compelling reason to use hevc265
265 requires more processing power to decode and display during real time play back -
And 29.97 fps is almost certainly the wrong frame rate. If 23.976 is the right frame rate you might be able to play the resulting file more smoothly.
What do you mean by "lags" and "drags"? Do you mean the audio and video are out of sync?
Removing vertical "dot crawl" stripes?
By skerit in forum RestorationReplies: 27Last Post: 18th Jul 2021, 21:56 -
What is the purpose of "Default" button in "Video" tab of XMedia Recode?
By MidnightUser in forum Newbie / General discussionsReplies: 1Last Post: 15th Jan 2016, 03:08 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 07:21 -
Horizontal "lines" across video conversion
By efiste2 in forum Video ConversionReplies: 6Last Post: 9th May 2015, 22:36 -
"Moving" vertical film lines
By Chief Mouse in forum RestorationReplies: 2Last Post: 1st Mar 2015, 13:13
