I've been given this DVR and it works fine EXCEPT: 1/ There's no audio to accompany the DVD or HDD video, and 2/ Even with a good antenna and good looking connections it won't tune in set-up and just says there's no signal and to check the antenna and connections.
I think Australia switched off the last analogue TV transmitter in 2013, so there is no signal for the antenna to receive. There is no digital tuner in that unit. These older units are only OK for replay, or recording from a non antenna source.
The audio problem does sound like either a unit or connection fault. -
Thanks for that as I didn't realise it was an analogue only device. I will chase the audio though as the DVD player is good.
Panasonic DMR-EZ485V recording problems
By ray best in forum DVD & Blu-ray RecordersReplies: 64Last Post: 18th Aug 2015, 19:19 -
Panasonic dmr-e100h & panasonic dmr e700bd recorders - disc release problem
By nanirdjeff in forum DVD & Blu-ray RecordersReplies: 1Last Post: 5th Apr 2015, 13:59 -
Panasonic DMR-EZ485V Audio problems
By klutz13 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 9th Oct 2014, 22:58 -
Panasonic DMR-ES35V - video problems
By Crystal990 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 18th Nov 2013, 06:00 -
Firmware problems panasonic dmr ez 27
By rick09 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 23rd Sep 2011, 22:22
