specs: dell laptop 64-bit windows 7 home premium
I was trying to update an old *.avs script file on my c: drive on my laptop but for some reason it won't let me edit files or create new files there any more, though i used to.
Maybe this is a recent windows update that is now blocking me from my own c: drive all the sudden.
Does anyone know how I can resolve this problem ?
Depends on exactly what caused the issue, but security and take ownership is usually the solution. "C:drive" covers a fairly wide range of area, is this file in a specific directory or in the root of C: as seems to be implied? If root, it should not be there and should be moved elsewhere, just as a policy matter, it is helpful to NOT allow the user access to the root of C: as an anti-virus measure.
yes, its in the root c:\ drive.
I moved the file to a new directory and its working.
When I attempted to delete the file, another dialog popped up "You'll need to provide administrator permission to delete this file".
[Continue] [Skip] [Cancel]
Naturally, I selected the [Continue] button and the file was deleted.
But I still want access to my c:\ drive. I can understand the virus/security measure, but if I could set up a couple of unlock.bat relock.bat scripts I would be happy to relock the c:\ drive. Anyway. Thanks for the info. -
run notepad or whatever you are using to edit the scripts with as admin. that should allow read/write in c: root. it also happens in c: windows folders and program folders.
Take ownership
http://www.howtogeek.com/howto/windows-vista/add-take-ownership-to-explorer-right-clic...-vista/windows 7/
http://www.howtogeek.com/wp-content/uploads/TakeOwnership.zip
I third this piece of software. I doubt that I would be using Windows 7 without it. -
i wouldn't. once admin is owner any malware can install silently.
please help to dl this video from nbc but Access Denied! Unable to downloa
By bfa1trung in forum Video Streaming DownloadingReplies: 18Last Post: 16th Sep 2015, 08:40 -
"403 Client error: Access denied" problem
By ekekezz in forum Video Streaming DownloadingReplies: 2Last Post: 31st Jul 2015, 18:28 -
How Do I Remote Access My Laptop to Home Network?
By Tommyknocker in forum ComputerReplies: 5Last Post: 14th Nov 2013, 10:19 -
Avi2DVD file access denied
By Imeil in forum Video ConversionReplies: 1Last Post: 27th Aug 2011, 08:29 -
Access denied to some files on one of my USB drives
By cal_tony in forum ComputerReplies: 6Last Post: 15th Apr 2011, 15:53
