I bought this to record video from my home DVR. I hooked it all up and it will record onto my laptop for about 7 minutes and then at some point it will stop recording and the screen will just freeze on my laptop. Any idea why. I am recording straight onto an external hard drive from my computer. Do I need more RAM?
Dump the idea of using an external drive ... use direct to pc drive capture only
Any sudden input signal quality drop will cause the unit to lockup, appear frozen
Any system interruption on usb connection will cause app to do the same
Disconnect all other devices connected via usb to prevent system interruption while recording is engaged.
See if that helps. -
dbondy1,please do not multi post the same question,i deleted your other posts,continue in this thread.
Turn off the power saving mode. I once had a situation where the computer would go into power saving mode since there was no keyboard or mouse movement and it would crash the video capture application.
The HD PVR uses USB to capture, so it would be a bad idea to capture to an external USB hard drive. It would be best to capture to the internal drive and then move the files to the external after the capture is complete.
SageTV Works With Hd pvr 2 Gaming Edition?
By Shlomi in forum CapturingReplies: 4Last Post: 15th Jul 2014, 13:24 -
PVR Gaming Edition 2
By muncher in forum Latest Video NewsReplies: 5Last Post: 25th Oct 2013, 19:53 -
Issue with Hauppauge HD PVR 2 Gaming Edition
By FilmNerd4 in forum CapturingReplies: 1Last Post: 16th Oct 2013, 18:39 -
Most optimal way to record with the PVR 2 Gaming edition?
By Jonz in forum CapturingReplies: 33Last Post: 1st Aug 2013, 00:42 -
Record PC Screen with the Hauppauge HDPVR Gaming Edition?
By rogvid700 in forum CapturingReplies: 5Last Post: 31st Jan 2012, 17:47
