Results 1 to 9 of 9
  1. Hi
    My video's audio is distorted (like robotic sound) after uploaded to Youtube (work perfectly if play in desktop, but problem in mobile) and Facebook.
    It's my first time having this problem.
    Wondering what is the problem?
    Here is info of the video file and original video file.
    General
    Complete name : C:\Downloads\Video\20160327kaishi-21handbrake.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42 (isom/iso2/avc1/mp41)
    File size : 1.79 MiB
    Duration : 22s 0ms
    Overall bit rate : 681 Kbps
    Encoded date : UTC 2016-03-28 04:06:38
    Tagged date : UTC 2016-03-28 04:06:38
    Writing application : HandBrake 0.10.3 2016012200
    Video
    Format : AVC
    Format profile : Main@L4
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : avc1
    Duration : 22s 0ms
    Bit rate : 522 Kbps
    Width : 854 pixels
    Height : 480 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.051
    Stream size : 1.37 MiB (77%)
    Writing library : x264 core 142 r2479 dd79a61
    Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=20000 / vbv_bufsize=25000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
    Color range : Limited
    Color primaries : BT.601 PAL
    Transfer characteristics : BT.709
    Matrix coefficients : BT.601
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 21s 990ms
    Bit rate mode : Variable
    Bit rate : 153 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Frame rate : 43.066 fps (1024 spf)
    Compression mode : Lossy
    Stream size : 410 KiB (22%)
    Title : Stereo / Stereo
    Default : Yes
    Alternate group : 1
  2. I tested by uploading the 20160327kaishi 21handbrake.mp4 to YouTube and there's nothing wrong with the audio.
  3. That's very nice of you.
    Here is the full version of the video, no problem if you play it in desktop.
    But audio has problem if you play it with phone (I am using iPhone, you can see in the comment, another user also reported "no sound" )
  4. I don't have a phone so someone else will have to test that. You originally said the audio got distorted after being uploaded to YouTube and I didn't have that problem myself. I tested back by playing on the computer.
  5. YouTube offers a number of different formats. It seems like some versions have broken sound (very quiet and distorted) and these are served to your iPhone but not to your desktop. Using youtube-dl they are the 3gp versions (numbers 17 and 36 in the format list). Try to report the problem to youtube. In the mean time maybe you can try to re-upload using a different format and see if it works. e.g.:
    ffmpeg -i "20160327kaishi-21handbrake.mp4" -c:v copy -c:a flac "output.mkv"
  6. Your attempt to make fake stereo from a mono track by inverting one channel is the problem.
  7. Good catch.
    Selecting only one of the channels (in case the recording software does not allow avoiding the problem in the first place):
    ffmpeg -i "20160327kaishi-21handbrake.mp4" -c:v copy -map_channel 0.1.0 -c:a flac "output.mkv"
  8. @manono It's ok, really appreciate your help.
    @jagabo Good catch!
    @sneaker Appreciate for listing out the code, I manage to solve it within second.
    I have spent several hours, keep converting and upload to try (newbie) here
    Once again thanks all!
  9. Hey, I am having the exact same problem. I'm not sure why but I can't figure out how you solved it based on the other comments. What am I missing? Also where do I fix this? Premiere pro? Handbrake? Thanks so much!
