I'm new to this whole thing to bear with me. Whenever I try to open up an MKV file into MKVExtractGUI to extract the file it says program not responding. Am I doing something wrong?
Try mkvcleaver instead,always works for me.
Yes I did move it to the same folder, but it still didn't work. I ended up using another program that worked for me
Another quick question. How do I use CC extractor for mp4? I just drag my file in? go to "Execution" tab and click on start, right? Because i'm doing that, but my .srt is coming out as 0bytes so pretty much not working.
Maybe it doesn't work with hard subs?Last edited by Klamp; 28th Mar 2016 at 02:49.
MKVExtractGUI doesn't work for me either. Normally I run MKVToolnix v7.9 but I decided to try v9.01. Unfortunately when trying to extract a subtitle with MKVExtractGUI it just hangs without even managing to show what files the MKV contains. Killing it still leaves MKVinfo stuck running in the background. This was with the portable version if that makes any difference.
MKVExtractGUI hasn't been updated in 10 years. Forget about it. There was a change in MKVtoolnix 9.0.0 that might have broken a number of tools relying on mkvinfo. Already updated and compatible with 9.0.0 and 9.0.1: gMKVExtractGUI.
Can't Extract Fonts With MKVExtractGUI
By RandolfS in forum SubtitleReplies: 3Last Post: 15th Aug 2013, 14:59 -
MKVExtractGUI and MKVCleaver both identify tracks incorrectly
By NDMMackay in forum Video ConversionReplies: 7Last Post: 21st May 2012, 22:44 -
MKVExtractGUI-2 vs MKVToolnix
By jandor2009 in forum Video ConversionReplies: 7Last Post: 6th Jan 2012, 20:06 -
MKV to MP4 Hell (MKVExtractGUI and YAMB)
By Axmann8 in forum Video ConversionReplies: 2Last Post: 6th Dec 2011, 06:50 -
MKVExtractGUI Subtitle extraction issues.
By TwitchFast in forum Newbie / General discussionsReplies: 2Last Post: 10th Oct 2011, 14:54
