The simplest solution: don't turn the Raspberry Pi off. It only consumes about 1 watt at idle. It will only cost you about $2/yr in electricity.
Results 31 to 36 of 36
Those are low powered devices, different approach is applicable here, always on, always ready.
3. It is OpenElec but interface is Kodi basically. OpenElec is something that allows you to boot into Kodi right away.
So your statement basically says, I do not like Kodi interface. Why is that? There might be different versions of Kodi for Raspberry , but basically all the same and similar. -
there are two ways how to watch stuff,
first is "movies", where everything is sorted by library, so your content could be on any device, anywhere on network and you just find it by your preferences (actor, year, genre etc.), but first you need to tell Kodi what directory, device, DLNA server to add and then you can run that particular directory or location with a scraper of your choice, that creates that virtual library (watch some tutorial). Running that scraper is optional, but it pulles informations and picture from web and it is graphically pleasant to browse. Of course you do not let run scraper throu home video locations, because it cannot pull appropriate data over web, it would only screw up naming and images.
second way is browsing as you were looking for, using video/files, but again, first you need to add a particular directory with video files. This way you can add many locations external hardrives, shared files over LAN and input passwords as well if applicable. For windows share files I use Zeroconf sharing over Windows smb
Do not be let down by this, it might take time to sort it all out first time,but it pays back later on. You do not have to navigate all over network after you create those locations, directories, services you go into videos or movies right away -
Skins. There's a wide variety of ways things can be displayed with different skins.
I am not a fan of Kodi's default Confluence Skin and have used Aeon Nox for a couple of years. About six months ago I started using Arctic Zephyr. I like these skins because I can add "Favorites" to the Kodi "Blade". That way if I have UPnP source or something else I can just add it to the Blade, maybe add a custom icon, etc. Makes the Wife (and family) Acceptance factor much higher.
I don't actually use the network shares and standard "Movies, Music, etc." that Kodi defaults to because I use a DLNA server, Mezzmo, that lets me organize my libraries and control access a lot better than Kodi can. I simply create shortcuts to the libraries I create on my server and put them on the Blade as favorites. You can't do that with the default skin. You'll always be tied to Kodi's way of doing things on a certain level but you can present things in a lot of different ways with some very different skins.
What specifically are you disappointed in?Last edited by smitbret; 20th Apr 2016 at 13:59.
Blu-ray Streaming
By tommyd17 in forum Newbie / General discussionsReplies: 8Last Post: 2nd Mar 2014, 15:39 -
Blu-ray streaming?
By tommyd17 in forum Newbie / General discussionsReplies: 2Last Post: 1st Mar 2014, 21:39 -
Ripping Blu-ray for streaming
By balornt in forum Blu-ray RippingReplies: 4Last Post: 17th Jul 2013, 14:43 -
blu ray iso to blu ray format
By minititan in forum Newbie / General discussionsReplies: 10Last Post: 30th Mar 2013, 15:49 -
Blu-Ray Streaming Setup
By Cybertron in forum Blu-ray RippingReplies: 1Last Post: 22nd Dec 2011, 19:40
