Is it possible to adjust volume level (gain) of MP3s WITHOUT loss of quality?
As far as I remember I read in the past that this is not possible.
Do I confuse something?
You can increase about .5 or 1.0(MAYBE....) in audio and wouldn't notice it much, but anything beyond that, you can notice the loss
MP3 and AAC can both have their volumes adjusted losslessly, in 1.5dB increments.
Mp3DirectCut can edit and change the volume of MP3s, even applying fad-ins and fade-outs without re-encoding. It can also edit raw AAC streams.
Or there's MP3Gain. It'll scan with ReplayGain and adjust the level accordingly, and there's a right click option for manually adjusting the volume. It can do the same for AAC in an M4A or MP4 container.
Foobar2000 can scan with ReplayGain and adjust losslessly as MP3Gain does.
Batch GAIN adjust for MP4's
By THRobinson in forum Newbie / General discussionsReplies: 5Last Post: 12th Nov 2013, 14:12 -
Find correct audio gain level
By walzing in forum DVD RippingReplies: 5Last Post: 1st Apr 2013, 21:16 -
Can Xvid4PSP 6 automatically adjust volume to a reasonable level?
By Short in forum Video ConversionReplies: 0Last Post: 24th Feb 2013, 02:15 -
Is there a volume normalizer for mp3s for android phones?
By yoda313 in forum Off topicReplies: 4Last Post: 12th Oct 2012, 18:06 -
Adjust audio level
By drgt in forum Newbie / General discussionsReplies: 7Last Post: 11th Aug 2011, 13:03
