Does anyone know if MPC-HC can be made to run BD menu's yet?
I've found a few very old comments via yahoo that it doesn't but
can't find any recent. It seems like this should be working now.
I'm trying to create a simple BD disc with multiAVCHD and am
just looking to test the output before burning it but things
don't seem at all right with the output.
No, MPC-HC doesn't work with Blu-ray menus.
If you need a free program to test Blu-ray menus, there are none that are foolproof. VLC can be set up to do some menus, though I don't know the exact steps. You'd have to do your own research there. The Leawo player can handle quite a few BD menus, but it will fail on some.
Your best bet would be PowerDVD or WinDVD, but they are not free. A new version of PowerDVD is due in the middle of next month. -
Thanks to both.
It's the menu's I need to test to see what can and can't play and to check the controls.
Right now all I get from MPC is a single file looping no matter how I set up multiAVHCD
I'm happy to buy software if there is something well written. So far I've not seen a single
package I'd waste my money on.
Does anyone know the full requirements to create a simple BD track menu setup on disc?
Maybe I'd be better off just writing my own? At least then I'd have a fair idea that things
will work.
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 167Last Post: 8th Dec 2022, 03:44 -
Runtime Error with MPC and MPC-HC
By jacatone in forum Software PlayingReplies: 2Last Post: 5th Oct 2013, 00:23 -
MPC-BE: how to display datacode (PGS-Subtitle) like in MPC-HC
By flashandpan007 in forum Software PlayingReplies: 0Last Post: 29th Apr 2013, 14:14 -
Always +125% video/Frame/Zoom size MPC-HC/MPC-BE?
By tigerb in forum Newbie / General discussionsReplies: 6Last Post: 8th Mar 2013, 16:57 -
MPC-HC settings?
By Hoser Rob in forum Software PlayingReplies: 4Last Post: 22nd Jan 2012, 10:51
