Hi
i downloaded the trial verion of The Catalyst Production Suite
is there a way to setup a scratch disk/folder?
i have several ssd , and i use a ssd for scratch disk
i have noticed that when i import a video , it saved on my mail ssd when i have the operation disk
thanks
Don't use the product -- but from my understanding your question doesn't really make sense.
You copy your footage from the camera to whatever location you choose, make your selections/changes in catalyst edit, and then export to the location of your choice.
Catalyst edit is meant to be a helper for Vegas, not a replacement, not a full-featured editor. (though it looks pretty capable.)
Help with hex edit of temp file
By ribsplitter in forum AudioReplies: 2Last Post: 25th Mar 2016, 10:15 -
Sorting external drive- folder view??
By aelfheah in forum ComputerReplies: 3Last Post: 10th Dec 2013, 17:52 -
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 16:23 -
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 19:09 -
RipBot264 Temp Folder
By jotpilot in forum Blu-ray RippingReplies: 12Last Post: 11th Jan 2012, 16:45
