Well this is my 1st ever problem with Movie
I have Ip Man 3 . I got subtitles but
problem is with audio all tracks are not properly recognized .
This is track list as origial
Audio:
. Cantonese LPCM Audio 5.1 / 48 kHz / 4608 kbps / 16-bit
. Cantonese DTS-HD Master Audio 7.1 / 48 kHz / 6580 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
. Cantonese Dolby TrueHD Audio 5.1 / 48 kHz / 2295 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps)
. Mandarin DTS-HD Master Audio 5.1 / 48 kHz / 2270 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
. Mandarin Dolby Digital Audio 5.1 / 48 kHz / 640 kbps
thing is all tracks are zhou and ( SD audio ) in audio panel
doesnt matter if i will remove LPCM or any other . Audio is completely out of sync.
Entire this is just 30GB
That mean i cant add subtitles using MultiAVC ? I have to do that using TSmuxer only? I want to store menu and all extras.
My point is too keep Cantoese as this movie is HK . Chinese is dub
I came across this problem too when i converted the same movie from MKV to bluray format using BD-REBUILDER.
The Cantonese audio was out of sync.
I have noticed there was an audio delay, just adjust the same by using TSMUXER and remux again.
Thanks.
Lee -
Solution was to cut 2 HD audios. Only Cantonese Master and Dolby True others were needless. In this movie Chinese/Mandarin is dubbed.
multiAVCHD Menu
By catracho2009 in forum Authoring (Blu-ray)Replies: 11Last Post: 29th Aug 2016, 17:18 -
MultiAVCHD
By Mart7 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2015, 15:20 -
Multiavchd not launching
By mou353 in forum Authoring (Blu-ray)Replies: 2Last Post: 23rd Feb 2014, 10:51 -
Need Help With MultiAVCHD
By ThomKelly in forum Video ConversionReplies: 2Last Post: 9th Feb 2014, 16:37 -
MultiavcHD alternates?
By digitalfreaknyc in forum Authoring (Blu-ray)Replies: 2Last Post: 26th May 2013, 21:01
