My editor (VSDC) crashes every time i try to import anything. Audio, video, add effects, copy-paste, every time it crashes. I also want to know if it's possible to import animated gifs into the editor via import picture tool or by any other means.
	Ok, i found out why my editor kept crashing! It seems like whenever an audio bar in the editor that doesn't actually contain an audio file, that's when it crashes. I'd imagine that a similar result to videos or anything like that. :P
	I got the same problem. VSDC launched a new beta where this bug seems to disappear. Try http:\\downloads.videosoftdev.com\video_tools\video_editor_update.exe
	Probably because it's CRAP.
 Get a better editor like Windows Live movie maker.
	Even a simple editor like Virtualdub can load an animated GIF. Stop using garbage s/w..... Got my retirement plans all set. Looks like I only have to work another 5 years after I die........
	I'd still like to figure out how to import .gifs. Whenever i try and use the "add picture" button and load in a gif that way, it loads the image, but the gif doesn't animate. any ideas?
	You have to convert the GIF to a PNG still sequence, then import to the NLE as a regular sequence.
  Importing MTS to Encore CS3By kshavo in forum Video ConversionReplies: 29Last Post: 4th Jul 2015, 12:57
  Importing Error: avi to ripbot264By vivabarca in forum Blu-ray RippingReplies: 2Last Post: 14th Feb 2015, 13:28
  RB-Rebuilder not importing PCM audio.By hbenthow in forum Authoring (Blu-ray)Replies: 15Last Post: 12th Jan 2015, 21:18
  Playing and importing problemBy Tactical Bear in forum EditingReplies: 2Last Post: 12th Jun 2014, 07:28
  Importing from APP to AE, why is it all black?By Devilsadvocate in forum EditingReplies: 5Last Post: 27th Mar 2012, 20:19
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
