I have tried two different files of the same movie, updated my codecs, and, gone to a new build of the system, and, for reasons I can't see, AVS to DVD is either stooping either during the authoring program (I have it set to create an iso image,) or, at teh start of the authoring program. The message window says to check the AVStoDVD log, and, the batchmux log. I found the batchmux log on one attempt, it told me nothing.
I have not had this problem with this system before, so four attempts with no success is unusual. All the parameters for the system are set to as they are when the system is downloaded.
Has something in the authoring program become corrupted?, could it possibly be the files I'm trying to convert (They're labeled brrips down in avi) ?
If the mod, or, someone could help me figure this out, I'd appreciate it.
			Closed Thread
	The following seems to the AVStoDVD log, from teh latest attempt.
 3/24/2016 7:14:16 AM>
 START PROCESS
 <3/24/2016 7:14:16 AM>
 PROJECT SETTINGS
 DVD Video Standard: NTSC
 DVD Titles number: 1
 DVD Size: 4450/4450 MB (100%)
 DVD Output Setup: ISO UDF Image
 DVD Label: DVStar Wars Episode VII the Force Awakens
 DVD Menu: No Menu
 Output Folder: C:\Users\Bill\Downloads\Star.Wars.Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO
 Delete Temp Assets Files: Yes
 Delete Temp Working Files: Yes
 Edit Command Parameters: No
 Post Process Task: Show Progress Status window
 PREFERENCES
 MultiThread: 1
 AVS Video Source Filter: A2DSource
 AVS Audio Source Filter: A2DSource
 AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize
 Frame Adjust Strategy: 0
 FPS Hard Conversion: 0
 PAL SpeedUp: 0
 NTSC SlowDown: 0
 Video Resolution: 0
 Video Encoder: 0
 Video BitRate Min: 2500
 Video BitRate Max: 8500
 Keep DVD Compliant Video: 1
 AC3 Audio Encoder: 0
 Force FFmpeg for Long Audio: 1
 DVD Audio Format: 0
 DVD Audio BitRate: 192
 Keep DVD Compliant Audio: 1
 Normalize Audio: 0
 Auto Delay Audio: 1
 DVD Audio Language (Primary): EN - English
 DVD Audio Language (Secondary): EN - English
 DVD Subs Language (Primary): EN - English
 DVD Subs Language (Secondary): EN - English
 DVD Subs Font: Tahoma 18pt (255,255,255)
 Chapters Interval: 5
 Use Source Chapters: 1
 DVD Burning Drive: D: ATAPI iHAS124 W HL0F
 DVD Burning Speed: 4x
 Auto Erase DVD RW: 1
 Unload ActiveMovie library: 0
 Adjust DirectShow Filters at runtime: 1
 Save General Settings: 1
 SYSTEM INFO
 Processor Name: AMD Athlon(tm) II X2 240 Processor
 Operating System: Windows 7 Service Pack 1 (64 bit)
 Current user is Admin: YES
 Available Output Disc Space: 267 GB
 AviSynth is installed: YES (release 2.6.0)
 LAV Filters is installed: YES (release 0.68.0)
 ffdshow is installed: NO
 CODECS REPORT
 H.264/AVC: Enhanced Video Renderer {FA10746C-9B63-4B6C-BC49-FC300EA5F256}
 Xvid: Enhanced Video Renderer {FA10746C-9B63-4B6C-BC49-FC300EA5F256}
 DivX 4/5/6: Enhanced Video Renderer {FA10746C-9B63-4B6C-BC49-FC300EA5F256}
 Other MPG4: Enhanced Video Renderer {FA10746C-9B63-4B6C-BC49-FC300EA5F256}
 DV: DV Video Decoder {B1B77C00-C3E4-11cf-AF79-00AA00B67A42}
 MPEG1: MPEG Video Codec {feb50740-7bef-11ce-9bd9-0000e202599c}
 MPEG2: Microsoft DTV-DVD Video Decoder {212690FB-83E5-4526-8FD7-74478B7939CD}
 MP2: Microsoft DTV-DVD Audio Decoder {E1F1A0B8-BEEE-490D-BA7C-066C40B5E2B9}
 MP3: MP3 Decoder DMO {BBEEA841-0A63-4F52-A7AB-A9B3A84ED38A}
 AAC: LAV Audio Decoder {E8E73B6B-4CB3-44A4-BE99-4F7BCB96E491}
 AC3: No Preferred Filter set
 <3/24/2016 7:14:17 AM>
 TITLE 1 SOURCE FILES
 Video: C:\Users\Bill\Downloads\Star.Wars.Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO\Star.Wars.Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO.avi
 Info: XviD - 1178 kbps - 720x304 - DAR 2.368 - 23.976 fps - Progressive - 2:18:07 hours - 198683 frames
 Audio 1: C:\Users\Bill\Downloads\Star.Wars.Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO\Star.Wars.Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO.avi
 Info: AC3 - 384 kbps - CBR - 6 ch - 48000 Hz - 2:18:07 hours (0 ms delay)
 [MediaInfoLib - v0.7.74]
 AVISYNTH SCRIPT
 Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
 Video = A2DVideoSource("C:\Users\Bill\Downloads\Star.Wars. Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO\Star.Wars.Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO.avi", CacheFolder="C:\Users\Bill\AppData\Local\Temp", FrameRateNum=2997, FrameRateDen=125, FrameRate=23.976)
 # Audio is frameserved by AviSynth just for Preview and Edit purposes.
 Audio = A2DAudioSource("C:\Users\Bill\Downloads\Star.Wars. Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO\Star.Wars.Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO.avi", CacheFolder="C:\Users\Bill\AppData\Local\Temp")
 Video = Video.ConvertToYV12()
 Video = Video.AddBorders(0,50,0,52)
 Video = Video.Lanczos4Resize(720,480)
 #PullDown: using DGPulldown/HCenc to upsize FPS
 AudioDub(Video, Audio)
 DIRECTSHOW AUDIO MIXER OPERATIONS:
 No LAV Filters mixer ON/OFF adjustment required at runtime
 START VIDEO ENCODING OPERATIONS
 Video Encoding Profile: HCenc VBR 2-pass
 Target Video FileSize: 3957.5 MB
 Encoding Parameters: -ini "C:\Users\Bill\AppData\Local\Temp\DVStar Wars Episode VII the Force Awakens_Star.Wars.Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO.HCenc.ini"
 HCenc ini file:
 *INFILE C:\Users\Bill\AppData\Local\Temp\DVStar Wars Episode VII the Force Awakens_Star.Wars.Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO_1.avs
 *AVSRELOAD
 *OUTFILE C:\Users\Bill\Videos\DVStar Wars Episode VII the Force Awakens_Star.Wars.Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO.m2v
 *LOGFILE C:\Users\Bill\AppData\Local\Temp\DVStar Wars Episode VII the Force Awakens_Star.Wars.Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO.HCenc.log
 *MAXBITRATE 9000
 *BITRATE 4006
 *PROFILE BEST
 *ASPECT 16:9
 *PROGRESSIVE
 *TFF
 *PULLDOWN
 *BIAS 40
 *DC_PREC 9
 *MATRIX MPEG
 *AQ 1
 *LUMGAIN 1
 *SMP
 *PRIORITY IDLE
 *DBPATH C:\Users\Bill\AppData\Local\Temp
 *WAIT 2
 <3/24/2016 8:41:10 AM>
 END VIDEO ENCODING OPERATIONS
 Video Source Filter: A2DSource (AVISource)
 Created File: C:\Users\Bill\Videos\DVStar Wars Episode VII the Force Awakens_Star.Wars.Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO.m2v (3959.7 MB)
 OUTPUT VIDEO INFO: MPEG-2 Video - 4008 kbps - 720x480 - DAR 16:9 - 23.976 fps - Progressive (2:3 Pulldown) - 2:18:07 hours - 248351 frames
 <3/24/2016 8:41:11 AM>
 START AUDIO DEMUXING OPERATIONS (Track 1)
 FFmpeg Parameters: -i "C:\Users\Bill\Downloads\Star.Wars.Episode.VII .The Force Awakens.2015.BRRip.XviD.AC3-EVO\Star.Wars.Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO.avi" -c:a copy -vn -sn -y "C:\Users\Bill\Videos\DVStar Wars Episode VII the Force Awakens_Star.Wars.Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO_1.ToFix.ac3"
 <3/24/2016 8:43:50 AM>
 START AC3 FIXING OPERATIONS (Track 1)
 ac3fix Parameters: "C:\Users\Bill\Videos\DVStar Wars Episode VII the Force Awakens_Star.Wars.Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO_1.ToFix.ac3" "C:\Users\Bill\Videos\DVStar Wars Episode VII the Force Awakens_Star.Wars.Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO_1.ac3"
 <3/24/2016 8:45:02 AM>
 END AUDIO DEMUXING OPERATIONS (Track 1)
 Created File: C:\Users\Bill\Videos\DVStar Wars Episode VII the Force Awakens_Star.Wars.Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO_1.ac3 (379.3 MB)
 OUTPUT AUDIO INFO: AC3 - 384 kbps - CBR - 6 ch - 48000 Hz - 2:18:07 hours (0 ms delay)
 DVD CHAPTERS CREATION OPERATIONS
 Title 1 Input Chapters List: 7193 14386 21578 28771 35964 43157 50350 57542 64735 71928 79121 86314 93506 100699 107892 115085 122278 129470 136663 143856 151049 158242 165434 172627 179820 187013 194206
 Title 1 Output Chapters List: 8991 17982 26972 35963 44954 53946 62937 71927 80918 89909 98901 107892 116882 125873 134864 143856 152847 161837 170828 179819 188811 197802 206792 215783 224774 233766 242757
 Created File: C:\Users\Bill\Videos\DVStar Wars Episode VII the Force Awakens_Star.Wars.Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO_Chapters.txt (206 Byte)
 START DVD AUTHORING OPERATIONS
 BatchMux Parameters: -arglist "C:\Users\Bill\AppData\Local\Temp\DVStar Wars Episode VII the Force Awakens_BatchMux.ini"
 BatchMux ini file:
 -d "C:\Users\Bill\Downloads\Star.Wars.Episode.VII .The Force Awakens.2015.BRRip.XviD.AC3-EVO\DVStar Wars Episode VII the Force Awakens\VIDEO_TS"
 -mxp "C:\Users\Bill\AppData\Local\Temp\DVStar Wars Episode VII the Force Awakens_MuxMan.mxp"
 -l "C:\Users\Bill\AppData\Local\Temp\DVStar Wars Episode VII the Force Awakens_MuxMan.log"
 -muxman "C:\Program Files (x86)\AVStoDVD\MuxMan"
 -prio LOW
 -palette "C:\Users\Bill\AppData\Local\Temp\DVStar Wars Episode VII the Force Awakens_Palette.txt"
 -v "C:\Users\Bill\Videos\DVStar Wars Episode VII the Force Awakens_Star.Wars.Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO.m2v"
 -vidmode LB
 -a1 "C:\Users\Bill\Videos\DVStar Wars Episode VII the Force Awakens_Star.Wars.Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO_1.ac3"
 -a1lang en
 -cellfr "C:\Users\Bill\Videos\DVStar Wars Episode VII the Force Awakens_Star.Wars.Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO_Chapters.txt"
 -progfr "C:\Users\Bill\Videos\DVStar Wars Episode VII the Force Awakens_Star.Wars.Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO_Chapters.txt"
 -chapfr "C:\Users\Bill\Videos\DVStar Wars Episode VII the Force Awakens_Star.Wars.Episode.VII.The Force Awakens.2015.BRRip.XviD.AC3-EVO_Chapters.txt"
 <3/24/2016 8:45:46 AM>
 Process aborted during DVD AUTHORING operations!
 Check following files for more details:
 AVStoDVD log file <C:\Users\Bill\Downloads\Star.Wars.Episode.VII.T he Force Awakens.2015.BRRip.XviD.AC3-EVO\DVStar Wars Episode VII the Force Awakens.log>
 BatchMux log file <C:\Users\Bill\Downloads\Star.Wars.Episode.VII.T he Force Awakens.2015.BRRip.XviD.AC3-EVO\DVStar Wars Episode VII the Force Awakens_BatchMux.log>
 For more troubleshooting on Authoring issues, see Help/FAQ/Authoring.
 <3/24/2016 8:46:48 AM>
 Warning! AVStoDVD Project ended with errors.
 Log file created by AVStoDVD Release 2.8.3
 and this is the batchmux log from the same attempt
 Segment memory resources --> RELEASED
 Local Stack memory --> RELEASED
 File i/o structures --> DEALLOCATED
 I hope these enable someone to figure out what is going wrong where.
  AVS-DVD Layer break problemBy efiste2 in forum Video ConversionReplies: 13Last Post: 1st Aug 2014, 04:01
  AVS 8.5- no Conversion Options for DVD outputBy clashradio in forum Video ConversionReplies: 3Last Post: 14th Jun 2014, 20:18
  AVS to DVD - PLEASE HELP!By noobish in forum Newbie / General discussionsReplies: 2Last Post: 20th Mar 2013, 17:30
  Unicode Text problem in avs and DVD Slideshow UIBy Farrukh in forum Newbie / General discussionsReplies: 3Last Post: 23rd Dec 2012, 09:57
  DVD Authoring with Windows MM 2.6 OR AVS AuthoringBy jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 05:41
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
