Preparing a number of files for uploading to streaming site (Vimeo)
My original file format was 720x576, 25fps PAL
As a result of processing these are now 960x720p ... and currently at 50fps due to de-interlacing.
I have to do final renders in any event to H264 ..... do I drop frame rate back to PAL rate of 25, or even change it to 30.
I did a test upload of 50, 30 & 25 and Vimeo seems happy with all 3........... just wondering what is best approach.
This is not for Youtube ............ it is Vimeo
Vimeo seems happy with 50 ..... just wanted to check if uploading at 50 gave any problem with any browsers, great if it doesn't. -
If it does, screw 'em! Tell your viewers to use a decent browser.
EDIT: Actually, does Vimeo truly support 720p50? The 720p50 and 1080p50 samples I've just looked at from a random search are frame-blended down to 30fps.Last edited by Brad; 23rd Mar 2016 at 10:01.
How to find out frame exposure time in a variable frame rate .mov file...
By bananas100 in forum EditingReplies: 5Last Post: 24th Oct 2014, 19:18 -
Bad File / Variable Frame rate from Skype Cap
By AceBlade258 in forum Video Streaming DownloadingReplies: 4Last Post: 4th Mar 2013, 13:00 -
Problems converting FLV file with ffmpeg and variable frame rate
By orev in forum Video ConversionReplies: 10Last Post: 28th Feb 2013, 22:49 -
What should slide show bit rate and frame rate be in video editor?
By johnharlin in forum Video ConversionReplies: 0Last Post: 11th Sep 2012, 21:00 -
MediaInfo: Frame Rate vs Original Frame Rate
By adalect in forum Video ConversionReplies: 1Last Post: 19th Aug 2012, 17:44
