Results 1 to 12 of 12
  1. A video created by Powerpoint from a slideshow displays the following information in MediaInfo:
    General
    Complete name                            : H:\SlideShow 1080 HD.mp4
    Format profile                           : Base Media / Version 2
    Codec ID                                 : mp42 (mp41/isom)
    File size                                : 42.4 MiB
    Duration                                 : 26s 537ms
    Overall bit rate                         : 13.4 Mbps
    Encoded date                             : UTC 2016-03-19 03:53:08
    Tagged date                              : UTC 2016-03-19 03:53:08
    Video
    Format profile                           : Baseline@L4
    Format settings, CABAC                   : No
    Format settings, ReFrames                : 2 frames
    Codec ID                                 : avc1
    Codec ID/Info                            : Advanced Video Coding
    Source duration                          : 26s 533ms
    Bit rate                                 : 13.4 Mbps
    Width                                    : 1 920 pixels
    Height                                   : 1 080 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 30.302 fps
    Bits/(Pixel*Frame)                       : 0.213
    Stream size                              : 42.4 MiB (100%)
    Source stream size                       : 42.4 MiB (100%)
    mdhd_Duration                            : 26532
    Audio
    Format                                   : AAC
    Format/Info                              : Advanced Audio Codec
    Format profile                           : LC
    Codec ID                                 : 40
    Bit rate mode                            : Constant
    Bit rate                                 : 25.7 Kbps
    Nominal bit rate                         : 192 Kbps
    Channel positions                        : Front: L R
    Sampling rate                            : 44.1 KHz
    Frame rate                               : 43.066 fps (1024 spf)
    Stream size                              : 83.2 KiB (0%)
    mdhd_Duration                            : 26537
    where it is stated the video is encoded in a Constant 30.302 fps frame rate. I have a problem uploading and playing this video on a web portal - some slides consistently stutter or display distortions - and I suspect the strange frame rate of 30.302 to be the cause of it. Whatever does it mean - 30.302 frames per second?
  2. I'm not sure about that. BUT: Since it is a slideshow converted into a video it may happen.
    Why don't you try to repack that video with mp4box and see the mediainfo again.
    Download mp4box and copy it to the video folder, open a command window there and type this command
    mp4box -add yourvideo.mp4 -new output.mp4
    Then check the video's mediainfo and confirm it.
  3. If you are going to reconvert it then i would suggest either 29.97 or 30.00
  4. You can create videos with whatever frame rate you want. Software players are pretty flexible when it comes to playing unusual frame rates. If a site like Youtube changes the frame rate from 30.3 to 30.0 fps it will do so by discarding one frame out of every 100, possibly creating a small jerk every ~3.3 seconds. If your video has no audio you may be able to change the frame rate in the header (no reencoding), slowing it down to 30 fps, and increasing the running time by 1 percent.
  5. Originally Posted by Adithya View Post
    What do you mean "copy it to the video folder", mp4box is a 20MB *.exe installer. Could you perhaps provide clearer instructions on how to use mp4box?
  6. Originally Posted by Aquinax View Post
    I did'nt mean the entire GPAC!! Here copy the content of all of this attachment to the folder.
    EDIT: Yeah you were right, my instructions were not very clear, Sorry.
  7. Adithya, to put it politely, I'm not sure you know what you're talking about.
  8. Originally Posted by Aquinax View Post
    Yeah i was thinking the same thing....
    EDIT: I was just answering the question of is it the correct framerate of the file.
    The answer to the second question is as jagabo suggested, is to repack the video with the framerate changed to 30 fps in it's header (If there are no audio streams) OP can do that by this ffmpeg command
    ffmpeg -i "His Video.mp4" -c copy -r 30 "Output Video.mp4"
    Thanks, jagabo,
    I think earlier you provided the fraction, by which 30.303 is calculated. I didn't know of it, and what was it again?
  10. Originally Posted by Aquinax View Post
    I don't understand what you're asking. 30.303 fps means each frame is supposed to be displayed for 1/30.303 seconds, about 0.0330000033 seconds. A display running at 60 Hz will display most frames for 2/60 second, but occasionally a frame will be displayed for only 1/60 second so that the average frame rate is 30.303 fps.
    Aug 2010
    San Francisco, California
    Your command will discard or duplicate frames to achieve 30 fps, which was the problem to begin with. The -r(ate) option needs to come before the input file:
    ffmpeg -r 30 -i "His Video.mp4" -c copy "Output Video.mp4"
