  1. I've created a bunch of scripts which can extract video and audio streams from any media
    files.
    In this archive there are a couple of batch files you can use to extract audio and video
    streams based on the mediainfo lite.
    How to:
    1)Install Mediainfo and check your files mediainfo to find in which formats are its video and
    audio streams.
    2) Download and copy ffmpeg to the directory where your video file is.
    3) Now extract the most suitable script according to your mediainfo into the folder of the
    video.
    4) Drag and Drop the video file into it, a process starts, after it finishes there will be two files
    "Video_Stream.(mp4,avi)" and "Audio_Stream.(m4a,mp3,ac3)" they are your splitted
    streams
    Below is a guide on which script to use on which files.
    Note: you should select your script by referring to these in your mediainfo
ID:	36288Name:  screenshot_39.jpg
    • Video: AVC, Audio: AAC - Script: AVCAAC.bat
    • Video: AVC, Audio: MP3 - Script: AVCMP3.bat
    • Video: AVC, Audio: AC3 - Script: AVCAC3.bat
    • Video: XVID, Audio: MP3 - Script: XVIDMP3.bat
    • Video: XVID, Audio: AC3 - Script: XVIDAC3.bat
    More formats coming soon.
    Please do post your opinions and suggestions and critics.
    Jul 2008
    Very good then, thanks!
  3. How to use ffmpeg
    Sent from my P4 using Tapatalk
