http://www.starsports.com/cricket/tour/icc-womens-t20-world-cup-2016-351/matchvideos/v...lay/index.html
I tried livestreamer to download the HDS stream but got the unknown tag type . video might be encrypted error while downloading HLS the quality 720p (2064k bitrate) is unavailable and it shows 404p as best which is wrong as I can play the stream in 720p in browser![]()
AnonymousGuestCode:
http://sshds9-lh.akamaihd.net/i/delayed/icct20wc2016g_ENGLISHICCT20WC16WOMENSENGVSIND22032016_1@398477/index_2064_av-b.m3u8?sd=10&rebase=on
Code:livestreamer "hls://sshds9-lh.akamaihd.net/i/delayed/icct20wc2016g_ENGLISHICCT20WC16WOMENSENGVSIND22032016_1@398477/index_2064_av-b.m3u8?sd=10&rebase=on" best -o 01.ts [cli][info] Found matching plugin stream for URL hls://sshds9-lh.akamaihd.net/i/delayed/icct20wc2016g_ENGLISHICCT20WC16WOMENSENGVSIND22032016_1@398477/index_2064_av-b.m3u8?sd=10&rebase=on [cli][info] Available streams: live (worst, best) [cli][info] Opening stream: live (hls)
Code:Video: MPEG4 Video (H264) 1280x720 25fps [V: h264 constrained baseline L3.1, yuv420p, 1280x720] Audio: AAC 44100Hz stereo 61kbps [A: aac lc, 44100 Hz, stereo, 61 kb/s]
@nullacht do you have any solution to download this video from same site ? I get 403 forbidden error everytime when I try livestreamer
Code:http://www.starsports.com/cricket/videos/vod/video=vivo-ipl-2016-opening-ceremony-jacqueline-kick-starts-the-vivo-ipl-opening-ceremony/index.html
Encrypted HDS Videos
By farafero21 in forum Video Streaming DownloadingReplies: 0Last Post: 15th Jan 2016, 14:30 -
HLS and HDS
By bhabani27 in forum Newbie / General discussionsReplies: 0Last Post: 17th Jun 2015, 02:17 -
so confused. HDS Link detector
By angles in forum Video Streaming DownloadingReplies: 3Last Post: 12th Dec 2014, 06:47 -
Help with capturing Adobe HDS stream.
By BlueBlack in forum Video Streaming DownloadingReplies: 7Last Post: 10th Apr 2014, 03:36 -
TWO external HDs not spinning up, what gives???
By sdsumike619 in forum ComputerReplies: 11Last Post: 9th Dec 2012, 12:04
