I having a problem using tsMuxeR on some movie.
Some movie output is ok but some ended up with (like in picture below)
Is there any suggestion that I can use to make it better?
Or any better software to use?
# I want to make custom Blu-Ray movie with only English Audio & Subs only (Remove all unwanted Audio & Subs) to saving up HDD space.
Without having any Video, Audio or Sub quality loss
# I mean custom Blu-Ray, that movie have BDMV & CERTIFICATE Folder, and inside BDMV there are various folder like real BD.
I not want to encode them, because encoding will have some quality loss for that movie. I just want to muxing them.
Here some detail about that Movie.:
Resolution: 1920x1080p
Frame rate: 23.976
Track info before start Muxing
Here the Meta file output shows before start Muxing:V:
Codec:H.264
Track Info: Profile: High@4.1 Resolution: 1920:1080p Framerate:23.976
A:
Codec: DTS-HD
Track Info: Bitrate: 1536Kbps core + MLP data.Sample Rate: 48KHz Channel 5.1 (DTS Master Audio)
S:
Codec: PGS
Track Info: Presentation Graphic Stream #0
That movie is play on MPC-HC, VLC & PowerDVD and give the same resultsMUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --label="Die Hard" --vbr --auto-chapters=5 --vbv-len=500
V_MPEG4/ISO/AVC, "D:\DieHard\BDMV\STREAM\00001.m2ts", insertSEI, contSPS, track=4113
A_DTS, "D:\DieHard\BDMV\STREAM\00001.m2ts", track=4352
S_HDMV/PGS, "D:\DieHard\BDMV\STREAM\00001.m2ts", fps=23.976, track=4608
I use printscreen software to capture the screen shot and crop it, because if I use in player "Save Image" or "Save Thumbnails" it will end up with no glitching
I has try another way, that is separate (demux) all contents inside that M2TS using MeGUI, The problem is I don't know what software to use to combine it to make 1 single M2TS without any quality loss. Also, to create BD-Structure for that file end up with .iso file
Results 1 to 1 of 1
Chroma Key Glitching
By XyDz in forum EditingReplies: 11Last Post: 4th May 2015, 08:05 -
tsMuxer Bluray output distorted
By JillB in forum Blu-ray RippingReplies: 10Last Post: 15th Aug 2013, 23:30 -
TSMuxer crashing error code -3 TSMuxer GUI
By petermg in forum Authoring (Blu-ray)Replies: 2Last Post: 30th Nov 2012, 15:21 -
Video Glitching
By Bertomotology in forum Authoring (DVD)Replies: 12Last Post: 6th Jul 2012, 02:19 -
DVDFab - Video glitching.
By meneedit in forum DVD RippingReplies: 3Last Post: 30th Jan 2012, 10:41
