Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
Results 1 to 9 of 9
    Sep 2014
    Rome
    Hi
    i wanted to try soundforge 11 under w10 64bit
    but the installation stoped with a warning about Microsoft .NET Framework 2.0
    on my w10 64bit pro i have not even Microsoft .NET Framework 3.5
    is it normal that a program like it needs Microsoft .NET Framework 2.0 ?
    did someone have the same issue?
    thanks
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    You paid $375.....demand an answer from Soundforge.
  3. When you say "I wanted to try Soundforge 11" I presume you mean you're running the trial before purchasing. While you can't demand an answer while on the trial, you can still use the online support.
    https://www.custcenter.com/app/answers/detail/a_id/4840/kw/dot%20net
    This FAQ article includes links to the .NET Framework and Visual C++ prerequisites for installation.
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
    --Benjamin Franklin
    Sep 2014
    Rome
    hi
    yes i wanted to try
    the problem is .NET Framework v2
    does somebody installed under w10 ?
    it doesn't even include framework 3.5
    thanks
    Sep 2014
    Rome
    hi
    but is there a subscription ?
    by the way yes i wanted to install the trial version
    Oct 2005
    666th portal
    yes they claim it works on w10 as long as your computer meets the minimum specs. http://www.sonycreativesoftware.com/soundforgepro/techspec
    and you can install/enable dot net 2 on win10 - http://www.groovypost.com/howto/enable-net-framework-2-windows-8/
    Sep 2014
    Rome
    hi
    thanks a lot
    i will try it
    but i can't understand why soundforge need framework 2 , to keep compatibility with xp ?
    is at least 64bit ?
    thanks
  8. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    soundforge i believe is a 32 bit program.
  9. Member Cornucopia's Avatar
    If it's a 32bit app, and they want to continue maintaining support for XP (which may be reasonable given their user base), it wouldn't make sense for them to fork and develop an additional application strictly for 7/8/10 64bit users (particularly if their feature set doesn't include anything that requires or takes major advantage of 64bit capability).
    In other words, if it's not broke why fix it?
