Closed Thread
Results 1 to 17 of 17
Can't you simply open the file in MeGui and do whatever you want with it?
sbs video is simply a video which shows two viewing angles next to each other, if you just want one view simply crop the other view away,...users currently on my ignore list: deadrats, Stears555, marcorocchini
I am sorry. I did not explain well . I'm working with BD3D2MK3D and I have a problem. When I load the BD in the program follow the steps but I encodes only six minutes . And I do not understand what I do wrong ...
Here is the AVISynth :
Code:# Avisynth script generated Sat Mar 19 15:21:33 CET 2016 by BD3D2MK3D v0.85 # to convert "C:\Users\pc\Documents\DVDFab9\Video\BDMV\PLAYLIST\00098.mpls" # (referencing the M2TS/SSIF files 00042) # to 3D Side-by-Side. # Movie title: point # # Source MPLS information: # MPLS file: 00098.mpls # Video : Und AVC, 1080p, 23.976 fps, left-eye # Video : Und MVC, 1080p, 23.976 fps, right-eye (32 3D-Planes) # Audio : Eng DTS-HD-Master, Multi-channel, 48 Khz # Audio : Eng AC3, Multi-channel, 48 Khz # Audio : Eng AC3, Multi-channel, 48 Khz # Audio : Fra AC3, Multi-channel, 48 Khz # Audio : Spa AC3, Multi-channel, 48 Khz # Audio : Por AC3, Multi-channel, 48 Khz # Audio : Rus AC3, Multi-channel, 48 Khz # Subtitle: Eng PGS, 3D-plane: 1 # Subtitle: Fra PGS, 3D-plane: 2 # Subtitle: Spa PGS, 3D-plane: 3 # Subtitle: Por PGS, 3D-plane: 4 # Subtitle: Rus PGS, 3D-plane: 5 # Subtitle: Spa PGS, 3D-plane: 6 # Subtitle: Por PGS, 3D-plane: 7 # Subtitle: Rus PGS, 3D-plane: 8 LoadPlugin("C:\Users\pc\Desktop\VirtualDubMod_1_5_10_2_All_inclusive\BD3D2MK3D\toolset\LoadHelper.dll") LoadPlugin("DGMVCDecode.dll") #LoadPlugin("FRIMSource.dll") #LoadPlugin("C:\Program Files (x86)\BDtoAVCHD\MVCSource.dll") ##LoadPlugin("VSFilter.dll") #LoadPlugin("SupTitle.dll") # Load the two video streams (9837 frames per stream) interleaved = DGMVCSource("00098.track_4113.264", "00098.track_4114.mvc", view = 0, frames = 9837, hw = 0) #interleaved = FRIMSource("mvc", "00098.track_4113.264", "00098.track_4114.mvc", num_frames = 9837, cache = 2, platform = "") #interleaved = MVCsource("00098.track_4113.264", "00098.track_4114.mvc", 9837, 2) # Current base view: left eye. # The views are in the common order: AVC stream = left view, MVC stream = right view. left = SelectEven(interleaved) right = SelectOdd(interleaved) # Build Side-by-Side stream StackHorizontal(HorizontalReduceBy2(Left), HorizontalReduceBy2(Right)) AssumeFPS("ntsc_film") # Hardcode subtitles ##VobSub(".sub") #SupTitle(".sup") # Return the 3D clip. Return(last)#.Info()
What does mediainfo say about the playlist?
Say :
Code:General Nombre completo : C:\Users\pc\Documents\DVDFab9\Video\BDMV\PLAYLIST\00098.mpls Formato : Blu-ray Playlist Tamaño del archivo : 746Bytes Duración : 1h 53min. Modo de tasa de bits : Variable Tasa de bits total : 1bps Video ID : 4114 (0x1012) / 4113 (0x1011) ID Menú : 1 (0x1) Formato : AVC Formato/Info : Advanced Video Codec Formato del perfil : Stereo High@L4.1 / High@L4.1 Ajustes del formato, CABAC : Si Ajustes del formato, RefFrames : 3marcos ID Códec : 27 Duración : 6min. Tipo de tasa de bits : Variable Tasa de bits máxima : 33,0Mbps Ancho : 1 920pixeles Alto : 1 080pixeles Relación de aspecto : 16:9 Velocidad de cuadro : 23,976 (24000/1001)fps ColorSpace : YUV ChromaSubsampling/String : 4:2:0 BitDepth/String : 8bits Tipo de exploración : Progresivo format_identifier : HDMV Source : 00060.m2ts / 00042.m2ts Audio #1 ID : 4352 (0x1100) ID Menú : 1 (0x1) Formato : DTS Formato/Info : Digital Theater Systems Formato del perfil : MA / Core Format_Settings_Mode : 16 Ajustes del formato, Endianness : Big Modo Muxing : Stream extension ID Códec : 134 Duración : 6min. Tipo de tasa de bits : Variable / Constante Tasa de bits : Desconocido / 1 509Kbps Canal(es) : 8canales / 6canales Posiciones del canal : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE Velocidad de muestreo : 48,0KHz Velocidad de cuadro : 93,750fps (512 spf) BitDepth/String : 16bits Compression_Mode/String : / Lossy Idioma : Inglés Source : 00042.m2ts Audio #2 ID : 4353 (0x1101) ID Menú : 1 (0x1) Formato : AC-3 Formato/Info : Audio Coding 3 Format_Settings_ModeExtension : CM (complete main) Ajustes del formato, Endianness : Big ID Códec : 129 Duración : 6min. Tipo de tasa de bits : Constante Tasa de bits : 640Kbps Canal(es) : 6canales Posiciones del canal : Front: L C R, Side: L R, LFE Velocidad de muestreo : 48,0KHz Velocidad de cuadro : 31,250fps (1536 spf) Tamaño de pista : 31,2MB Idioma : Inglés bsid : 6 dialnorm : -27 dialnorm : -27 dB compr : -0.28 compr : -0.28 dB acmod : 7 lfeon : 1 dialnorm_Average : -27 dialnorm_Average : -27 dB dialnorm_Minimum : -27 dialnorm_Minimum : -27 dB dialnorm_Maximum : -27 dialnorm_Maximum : -27 dB dialnorm_Count : 638 compr_Average : 0.37 compr_Average : 0.37 dB compr_Minimum : -1.80 compr_Minimum : -1.80 dB compr_Maximum : 3.88 compr_Maximum : 3.88 dB compr_Count : 638 format_identifier : AC-3 Source : 00042.m2ts Audio #3 ID : 4354 (0x1102) ID Menú : 1 (0x1) Formato : AC-3 Formato/Info : Audio Coding 3 Format_Settings_ModeExtension : CM (complete main) Ajustes del formato, Endianness : Big ID Códec : 129 Duración : 6min. Tipo de tasa de bits : Constante Tasa de bits : 640Kbps Canal(es) : 6canales Posiciones del canal : Front: L C R, Side: L R, LFE Velocidad de muestreo : 48,0KHz Velocidad de cuadro : 31,250fps (1536 spf) Tamaño de pista : 31,2MB Idioma : Inglés bsid : 6 dialnorm : -27 dialnorm : -27 dB compr : -0.28 compr : -0.28 dB acmod : 7 lfeon : 1 dialnorm_Average : -27 dialnorm_Average : -27 dB dialnorm_Minimum : -27 dialnorm_Minimum : -27 dB dialnorm_Maximum : -27 dialnorm_Maximum : -27 dB dialnorm_Count : 638 compr_Average : 0.22 compr_Average : 0.22 dB compr_Minimum : -2.14 compr_Minimum : -2.14 dB compr_Maximum : 4.22 compr_Maximum : 4.22 dB compr_Count : 638 format_identifier : AC-3 Source : 00042.m2ts Audio #4 ID : 4355 (0x1103) ID Menú : 1 (0x1) Formato : AC-3 Formato/Info : Audio Coding 3 Format_Settings_ModeExtension : CM (complete main) Ajustes del formato, Endianness : Big ID Códec : 129 Duración : 6min. Tipo de tasa de bits : Constante Tasa de bits : 640Kbps Canal(es) : 6canales Posiciones del canal : Front: L C R, Side: L R, LFE Velocidad de muestreo : 48,0KHz Velocidad de cuadro : 31,250fps (1536 spf) Tamaño de pista : 31,2MB Idioma : Francés bsid : 6 dialnorm : -27 dialnorm : -27 dB compr : -0.28 compr : -0.28 dB acmod : 7 lfeon : 1 dialnorm_Average : -27 dialnorm_Average : -27 dB dialnorm_Minimum : -27 dialnorm_Minimum : -27 dB dialnorm_Maximum : -27 dialnorm_Maximum : -27 dB dialnorm_Count : 638 compr_Average : 4.53 compr_Average : 4.53 dB compr_Minimum : -0.86 compr_Minimum : -0.86 dB compr_Maximum : 6.02 compr_Maximum : 6.02 dB compr_Count : 638 format_identifier : AC-3 Source : 00042.m2ts Audio #5 ID : 4356 (0x1104) ID Menú : 1 (0x1) Formato : AC-3 Formato/Info : Audio Coding 3 Format_Settings_ModeExtension : CM (complete main) Ajustes del formato, Endianness : Big ID Códec : 129 Duración : 6min. Tipo de tasa de bits : Constante Tasa de bits : 640Kbps Canal(es) : 6canales Posiciones del canal : Front: L C R, Side: L R, LFE Velocidad de muestreo : 48,0KHz Velocidad de cuadro : 31,250fps (1536 spf) Tamaño de pista : 31,2MB Idioma : Español bsid : 6 dialnorm : -27 dialnorm : -27 dB compr : -0.28 compr : -0.28 dB acmod : 7 lfeon : 1 dialnorm_Average : -27 dialnorm_Average : -27 dB dialnorm_Minimum : -27 dialnorm_Minimum : -27 dB dialnorm_Maximum : -27 dialnorm_Maximum : -27 dB dialnorm_Count : 638 compr_Average : 4.55 compr_Average : 4.55 dB compr_Minimum : -0.56 compr_Minimum : -0.56 dB compr_Maximum : 6.02 compr_Maximum : 6.02 dB compr_Count : 638 format_identifier : AC-3 Source : 00042.m2ts Audio #6 ID : 4357 (0x1105) ID Menú : 1 (0x1) Formato : AC-3 Formato/Info : Audio Coding 3 Format_Settings_ModeExtension : CM (complete main) Ajustes del formato, Endianness : Big ID Códec : 129 Duración : 6min. Tipo de tasa de bits : Constante Tasa de bits : 640Kbps Canal(es) : 6canales Posiciones del canal : Front: L C R, Side: L R, LFE Velocidad de muestreo : 48,0KHz Velocidad de cuadro : 31,250fps (1536 spf) Tamaño de pista : 31,2MB Idioma : Portugués bsid : 6 dialnorm : -27 dialnorm : -27 dB compr : -0.28 compr : -0.28 dB acmod : 7 lfeon : 1 dialnorm_Average : -27 dialnorm_Average : -27 dB dialnorm_Minimum : -27 dialnorm_Minimum : -27 dB dialnorm_Maximum : -27 dialnorm_Maximum : -27 dB dialnorm_Count : 638 compr_Average : 4.54 compr_Average : 4.54 dB compr_Minimum : -1.16 compr_Minimum : -1.16 dB compr_Maximum : 6.02 compr_Maximum : 6.02 dB compr_Count : 638 format_identifier : AC-3 Source : 00042.m2ts Audio #7 ID : 4358 (0x1106) ID Menú : 1 (0x1) Formato : AC-3 Formato/Info : Audio Coding 3 Format_Settings_ModeExtension : CM (complete main) Ajustes del formato, Endianness : Big ID Códec : 129 Duración : 6min. Tipo de tasa de bits : Constante Tasa de bits : 640Kbps Canal(es) : 6canales Posiciones del canal : Front: L C R, Side: L R, LFE Velocidad de muestreo : 48,0KHz Velocidad de cuadro : 31,250fps (1536 spf) Tamaño de pista : 31,2MB Idioma : Ruso bsid : 6 dialnorm : -27 dialnorm : -27 dB compr : -0.28 compr : -0.28 dB acmod : 7 lfeon : 1 dialnorm_Average : -27 dialnorm_Average : -27 dB dialnorm_Minimum : -27 dialnorm_Minimum : -27 dB dialnorm_Maximum : -27 dialnorm_Maximum : -27 dB dialnorm_Count : 638 compr_Average : 4.50 compr_Average : 4.50 dB compr_Minimum : -1.16 compr_Minimum : -1.16 dB compr_Maximum : 6.02 compr_Maximum : 6.02 dB compr_Count : 638 format_identifier : AC-3 Source : 00042.m2ts Audio #8 ID : 4359 (0x1107) ID Menú : 1 (0x1) Formato : AC-3 Formato/Info : Audio Coding 3 Format_Settings_ModeExtension : CM (complete main) Ajustes del formato, Endianness : Big ID Códec : 129 Duración : 6min. Tipo de tasa de bits : Constante Tasa de bits : 640Kbps Canal(es) : 6canales Posiciones del canal : Front: L C R, Side: L R, LFE Velocidad de muestreo : 48,0KHz Velocidad de cuadro : 31,250fps (1536 spf) Tamaño de pista : 31,2MB Idioma : Japonés bsid : 6 dialnorm : -27 dialnorm : -27 dB compr : -0.28 compr : -0.28 dB acmod : 7 lfeon : 1 dialnorm_Average : -27 dialnorm_Average : -27 dB dialnorm_Minimum : -27 dialnorm_Minimum : -27 dB dialnorm_Maximum : -27 dialnorm_Maximum : -27 dB dialnorm_Count : 638 compr_Average : 4.54 compr_Average : 4.54 dB compr_Minimum : -0.28 compr_Minimum : -0.28 dB compr_Maximum : 6.02 compr_Maximum : 6.02 dB compr_Count : 638 format_identifier : AC-3 Source : 00042.m2ts Texto #1 ID : 4608 (0x1200) ID Menú : 1 (0x1) Formato : PGS ID Códec : 144 Duración : 1h 53min. Idioma : Japonés Source : 00042.m2ts Texto #2 ID : 4609 (0x1201) ID Menú : 1 (0x1) Formato : PGS ID Códec : 144 Duración : 1h 53min. Idioma : Inglés Source : 00042.m2ts Texto #3 ID : 4610 (0x1202) ID Menú : 1 (0x1) Formato : PGS ID Códec : 144 Duración : 1h 53min. Idioma : Francés Source : 00042.m2ts Texto #4 ID : 4611 (0x1203) ID Menú : 1 (0x1) Formato : PGS ID Códec : 144 Duración : 1h 53min. Idioma : Español Source : 00042.m2ts Texto #5 ID : 4612 (0x1204) ID Menú : 1 (0x1) Formato : PGS ID Códec : 144 Duración : 1h 53min. Idioma : Portugués Source : 00042.m2ts Texto #6 ID : 4613 (0x1205) ID Menú : 1 (0x1) Formato : PGS ID Códec : 144 Duración : 1h 53min. Idioma : Ruso Source : 00042.m2ts Texto #7 ID : 4614 (0x1206) ID Menú : 1 (0x1) Formato : PGS ID Códec : 144 Duración : 1h 53min. Idioma : Español Source : 00042.m2ts Texto #8 ID : 4615 (0x1207) ID Menú : 1 (0x1) Formato : PGS ID Códec : 144 Duración : 1h 53min. Idioma : Portugués Source : 00042.m2ts Texto #9 ID : 4616 (0x1208) ID Menú : 1 (0x1) Formato : PGS ID Códec : 144 Idioma : Ruso Source : 00042.m2ts Texto #10 ID : 4617 (0x1209) ID Menú : 1 (0x1) Formato : PGS ID Códec : 144 Idioma : Japonés Source : 00042.m2ts Menú 00:00:00.000 : Chapter 1 00:10:11.819 : Chapter 2 00:21:05.138 : Chapter 3 00:29:20.925 : Chapter 4 00:42:44.895 : Chapter 5 00:50:05.794 : Chapter 6 01:03:19.462 : Chapter 7 01:12:43.942 : Chapter 8 01:20:40.418 : Chapter 9 01:27:14.520 : Chapter 10 01:32:44.350 : Chapter 11 01:39:02.603 : Chapter 12 01:53:50.657 : Chapter 13
Okay, I think I see the problem.
You are probably using the wrong playlist or those tools only support playlists with only one m2ts file in them.
The mediainfo output indicates that:
a. the duration of the playlist should be 1h 53min.
b. the duration of 00042.m2ts is only 6min.users currently on my ignore list: deadrats, Stears555, marcorocchini
I don `t believe. DVDFab did a very good sbs file from 00042.m2ts.
DVDFab mkv
But I do not like mkv parameters . I think they can improve . For this I use MeGUI to modify x264 easier. Maybe the disk has CineVia ( disk protection ) .Code:General UniqueID/String : 206174392128514935217241953182059818406 (0x9B1BBE59B9ED1C88B539E50B5D176DA6) Nombre completo : G:\POINT_BREAK.Title98.mkv Formato : Matroska Formato de la versión : Version 2 Tamaño del archivo : 14,1GIB Duración : 1h 53min. Tasa de bits total : 17,7Mbps Película : POINT_BREAK.Title98 Fecha de codificación : UTC 2016-03-18 02:37:18 Aplicación de codifición : DVDFab 9.2.2.6 Librería de codificación : libebml v0.7.8 + libmatroska v0.8.1 Video ID : 1 Formato : AVC Formato/Info : Advanced Video Codec Formato del perfil : High@L4.1 Ajustes del formato, CABAC : Si Ajustes del formato, RefFrames : 5marcos ID Códec : V_MPEG4/ISO/AVC Duración : 1h 53min. Tasa de bits nominal : 14,2Mbps Ancho : 1 920pixeles Alto : 1 080pixeles Relación de aspecto : 16:9 Modo de velocidad de cuadro : Constante Velocidad de cuadro : 23,976 (24000/1001)fps ColorSpace : YUV ChromaSubsampling/String : 4:2:0 BitDepth/String : 8bits Tipo de exploración : Progresivo Bits/(Pixel*cuadro) : 0.285 Librería de codificación : x264 core 142 Opciones de codificación : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0 / me=hex / subme=5 / psy=0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=2 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=0 / keyint=24 / keyint_min=13 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=14170 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00 Default : Si Forced : No colour_range : Limited colour_primaries : BT.709 transfer_characteristics : BT.709 matrix_coefficients : BT.709 Audio #1 ID : 2 Formato : AC-3 Formato/Info : Audio Coding 3 Format_Settings_ModeExtension : CM (complete main) Ajustes del formato, Endianness : Big ID Códec : A_AC3 Duración : 1h 53min. Tipo de tasa de bits : Constante Tasa de bits : 640Kbps Canal(es) : 6canales Posiciones del canal : Front: L C R, Side: L R, LFE Velocidad de muestreo : 48,0KHz Velocidad de cuadro : 31,250fps (1536 spf) Tamaño de pista : 521MB (4%) Idioma : Español Default : Si Forced : No Audio #2 ID : 3 Formato : DTS Formato/Info : Digital Theater Systems Formato del perfil : MA / Core Format_Settings_Mode : 16 Ajustes del formato, Endianness : Big ID Códec : A_DTS Duración : 1h 53min. Tipo de tasa de bits : Variable / Constante Tasa de bits : Desconocido / 1 509Kbps Canal(es) : 8canales / 6canales Posiciones del canal : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE Velocidad de muestreo : 48,0KHz Velocidad de cuadro : 93,750fps (512 spf) BitDepth/String : 16bits Compression_Mode/String : / Lossy Idioma : Inglés Default : No Forced : No Menú 00:00:00.000 : en:(01)00:00:00:000 00:10:11.819 : en:(02)00:10:11:819 00:21:05.138 : en:(03)00:21:05:138 00:29:20.925 : en:(04)00:29:20:925 00:42:44.895 : en:(05)00:42:44:895 00:50:05.794 : en:(06)00:50:05:794 01:03:19.462 : en:(07)01:03:19:462 01:12:43.942 : en:(08)01:12:43:942 01:20:40.418 : en:(09)01:20:40:418 01:27:14.520 : en:(10)01:27:14:520 01:32:44.350 : en:(11)01:32:44:350 01:39:02.603 : en:(12)01:39:02:603 01:53:50.657 : en:(13)01:53:50:657
I'm the author of BD3D2MK3D and I don't understand your problem.
I have also Point Break. I have converted that title without problem to SBS.
Here is what I see in tab 1 of BD3D2MK3D for 00098.mpls:
Can you confirm that you see the same thing? What decrypter do you use? AnyDVD HD?Code:Streams of 00098.mpls, 1:53:50, 13 chapters, 00042.ssif : Video : Und AVC, 1080p, 23.976 fps, left-eye Video : Und MVC, 1080p, 23.976 fps, right-eye (32 3D-Planes) Audio : Eng DTS-HD-Master, Multi-channel, 48 Khz Audio : Eng AC3, Multi-channel, 48 Khz Audio : Eng AC3, Multi-channel, 48 Khz Audio : Fra AC3, Multi-channel, 48 Khz Audio : Spa AC3, Multi-channel, 48 Khz Audio : Por AC3, Multi-channel, 48 Khz Audio : Rus AC3, Multi-channel, 48 Khz Subtitle: Eng PGS, 3D-plane: 1 Subtitle: Fra PGS, 3D-plane: 2 Subtitle: Spa PGS, 3D-plane: 3 Subtitle: Por PGS, 3D-plane: 4 Subtitle: Rus PGS, 3D-plane: 5 Subtitle: Spa PGS, 3D-plane: 6 Subtitle: Por PGS, 3D-plane: 7 Subtitle: Rus PGS, 3D-plane: 8
Also, does the log tells something special, such as a problem reported by tsMuxeR during the demux process?
What are the sizes of the .264 and .mvc streams on disc, after the demux?
Anyway, it's certainly not a problem with Cinavia. Cinavia is only a watermark, and should not prevent the correct demuxing of the streams. I think the problem could be caused by a badly decrypted BD.r0lZ - PgcEdit homepage Hosted by VideoHelp (Thanks Baldrick)
- BD3D2MK3D A tool to convert 3D BD to 3D SBS/T&B/FS MKV
I've tried other blu ray and gives me the same error.
Avisynth script
Code:# Avisynth script generated Sun Mar 20 10:56:12 CET 2016 by BD3D2MK3D v0.85 # to convert "C:\Users\pc\AppData\Local\Temp\Rar$DRa0.153\BDMV\PLAYLIST\00003.mpls" # (referencing the M2TS/SSIF files 00003, 00005) # to 3D Side-by-Side. # Movie title: Sanctum # # Source MPLS information: # MPLS file: 00003.mpls # Video : Und AVC, 1080p, 23.976 fps, left-eye # Video : Und MVC, 1080p, 23.976 fps, right-eye (32 3D-Planes) # Audio : Eng AC3, Multi-channel, 48 Khz # Audio : Eng DTS-HD-Master, Multi-channel, 48 Khz # Subtitle: Zho PGS, 3D-plane: undefined # Subtitle: Eng PGS, 3D-plane: undefined LoadPlugin("C:\Users\pc\Desktop\VirtualDubMod_1_5_10_2_All_inclusive\BD3D2MK3D\toolset\LoadHelper.dll") LoadPlugin("DGMVCDecode.dll") #LoadPlugin("FRIMSource.dll") #LoadPlugin("C:\Program Files (x86)\BDtoAVCHD\MVCSource.dll") #LoadPlugin("VSFilter.dll") ##LoadPlugin("SupTitle.dll") # Load the two video streams (17820 frames per stream) interleaved = DGMVCSource("00003.track_4113.264", "00003.track_4114.mvc", view = 0, frames = 17820, hw = 0) #interleaved = FRIMSource("mvc", "00003.track_4113.264", "00003.track_4114.mvc", num_frames = 17820, cache = 2, platform = "") #interleaved = MVCsource("00003.track_4113.264", "00003.track_4114.mvc", 17820, 2) # Current base view: left eye. # The views are in the common order: AVC stream = left view, MVC stream = right view. left = SelectEven(interleaved) right = SelectOdd(interleaved) # Build Side-by-Side stream StackHorizontal(HorizontalReduceBy2(Left), HorizontalReduceBy2(Right)) AssumeFPS("ntsc_film") # Hardcode subtitles #VobSub(".sub") ##SupTitle(".sup") # Return the 3D clip. Return(last)#.Info()
AVISynth script (Point Breack)
With BD3D2AVS all goes well until it gives me this error :Code:# Avisynth script generated Mon Mar 21 23:35:32 CET 2016 by BD3D2AVS v0.12 # to convert "F:\BDMV\STREAM\SSIF\00042.ssif" # (referenced by playlist 00098.mpls) # to Half Side by Side steroscopic video file # Movie title: point # # Source MPLS information: # MPLS file: 00098.mpls # 1: Chapters, 12 chapters # 2: h264/AVC (left eye), 1080p, fps: 24 /1.001 (16:9) # 3: h264/AVC (right eye), 1080p, fps: 24 /1.001 (16:9) # 4: DTS Master Audio, English, 7.1 channels, 16 bits, 48kHz # (core: DTS, 5.1 channels, 16 bits, 1509kbps, 48kHz) # 5: AC3, English, 5.1 channels, 640kbps, 48kHz, dialnorm: 27dB # 6: AC3, English, 5.1 channels, 640kbps, 48kHz, dialnorm: 27dB # 7: AC3, French, 5.1 channels, 640kbps, 48kHz, dialnorm: 27dB # 8: AC3, Spanish, 5.1 channels, 640kbps, 48kHz, dialnorm: 27dB # 9: AC3, Portuguese, 5.1 channels, 640kbps, 48kHz, dialnorm: 27dB # 10: AC3, Russian, 5.1 channels, 640kbps, 48kHz, dialnorm: 27dB # 11: AC3, Japanese, 5.1 channels, 640kbps, 48kHz, dialnorm: 27dB # 12: Subtitle (PGS), Japanese # 13: Subtitle (PGS), English # 14: Subtitle (PGS), French # 15: Subtitle (PGS), Spanish # 16: Subtitle (PGS), Portuguese # 17: Subtitle (PGS), Russian # 18: Subtitle (PGS), Spanish # 19: Subtitle (PGS), Portuguese # 20: Subtitle (PGS), Russian # 21: Subtitle (PGS), Japanese LoadPlugin("C:\Users\Propietario\Desktop\BD3D2AVS\toolset\ssifSource.dll") SP_LEFTVIEW = 1 SP_RIGHTVIEW = 2 SP_HORIZONTAL = 4 ssifSource("F:\BDMV\STREAM\SSIF\00042.ssif", 1920, 1080, 163778, 1, 2, show_params = SP_LEFTVIEW + SP_RIGHTVIEW + SP_HORIZONTAL) AssumeFPS("ntsc_film") BilinearResize(1920, 1080) # Add 3 seconds of black at the end of the video Return(last + BlankClip(last, 72))#.Info()
You haven't replied to my questions. I can't help. The AVS script is useless for me. I repeat:
And yes, Vista should be OK, although you are probably the only one still using the most crappy OS ever !
BD3D2AVS is now totally obsolete, and I don't maintain it any more. Please use only the latest version of BD3D2MK3D.r0lZ - PgcEdit homepage Hosted by VideoHelp (Thanks Baldrick)
3D Bluray to SBS MKV on OS X
By ddregs in forum Blu-ray RippingReplies: 1Last Post: 7th Jan 2016, 15:10 -
Create Bluray (MKV->Bluray) with custom menu
By ThaDraGun in forum Authoring (Blu-ray)Replies: 1Last Post: 17th Aug 2015, 19:52 -
Full SBS to Half SBS
By sjb8622 in forum Newbie / General discussionsReplies: 0Last Post: 8th Jan 2013, 23:38 -
Converting Left Right 3D MKV to Half SBS MKV
By TehBotolSOsro in forum Video ConversionReplies: 10Last Post: 3rd Apr 2012, 06:24 -
Can I watch a 3D SBS MKV file on my NON 3D Bluray player?
By supaugly in forum Video ConversionReplies: 0Last Post: 10th Feb 2012, 19:45
