Results 1 to 9 of 9
  1. Hello
    Opened "AVS SCRIPT CREATOR" AND then opened the input
    and click on the one click encoder
    In the Avisynth profile> config >template
    My template is:
    LoadPlugin("C:\path\MeGUI\MeGUI_2624_x86\tools\avisynth_plugin\VSFilter.dll")
    <input>
    <resize>
    textsub("c:\1.ssa")
    After click on the "Go" Operation begins
    After finishing the application gives me a few files with this extension:
    .ac3
    .ass
    .m4a
    .avs
    .lwi
    while it should give me a video files
    Please help me how i can solve that.
    I guess you want to hardcode/burn in the subtitles in the video?
    Does the m4a has burned in subtitles? Then mux/join the m4a and ac3 together with a multipexer. I think megui has one under tools.
    If everything fails try xvid4psp 5 to hardcode your subtitles to a mp4.
  3. Originally Posted by Baldrick View Post
    I have a MKV file with 2GB
    I want convert it to MKV with ~500MB
    I Attached the logfile and the image of folder that MeGUI give me.
  4. AC3 is the extracted audio.
    AVS is you script.
    LWI is an L-Smash index file
    .264 would have been the video file, has not the process failed.
    From your log file:
    MeGUI\MeGUI_2624_x86\tools\x264\avs4x264mod.exe" --level 4.1 --preset veryslow --tune film --pass 2 --bitrate 1000 --stats "C:\testMeGUI\bq3mn1sh.vpt\testMeGUI_Video.stats" --keyint 240 --vbv-bufsize 78125 --vbv-maxrate 62500 --output "C:\testMeGUI\bq3mn1sh.vpt\testMeGUI_Video.264 " "C:\testMeGUI\bq3mn1sh.vpt\testMeGUI.mkv.avs"
    ---[Error] [3/22/2016 4:52:03 AM] x264 [error]: ratecontrol_init: can't open stats file
    ---[Error] [3/22/2016 4:52:03 AM] x264 [error]: x264_encoder_open failed
    I assume you're using the OneClick encoder which I never use myself, but it appears you have the x264 encoder preset you're using for this particular encode or OneClick profile, set for the second pass of a 2 pass encode and the first pass hasn't been run. If that's the case you can change the x264 preset to "automated 2 pass", or even set it to CRF encoding and specify a file size when setting up the OneClick encode (you'll need to select "show advanced settings" at the bottom of the OneClick window). If you select a file size MeGUI should work out the required video bitrate and switch to 2 pass encoding for you.
  5. There's also this:
    --[Information] [3/22/2016 4:49:50 AM] Target device: DXVA
    --[Information] [3/22/2016 4:49:57 AM] Input resolution: 1280x718
    --[Information] [3/22/2016 4:49:57 AM] Desired maximum width: 1280
    --[Information] [3/22/2016 4:49:57 AM] Desired maximum width not reached. Enable upsizing in the AviSynth profile if you want to force it.
    --[Information] [3/22/2016 4:49:57 AM] Output resolution: 1264x704
    Here's what I "think" is happening (I'm not 100% sure).
    Your AVIsynth profile is probably set for mod16 resizing. The input video is 1280x718 which isn't mod16. Upscaling in the Avisynth profile is disabled and MeGUI takes that very literally, so instead of resizing you up to 1280x720 (mod16), it's resizing down to 1264x704 instead. To correct that you probably need to open the Script Creator, then your Avisynth profile, and under the Extra Setup tab, enable upsizing. I think it's a terrible idea to have the upscaling option hidden away and disabled by default, but there it is. You might also want to change the mod setting to mod4 to allow more accurate resizing.
    Or there's an option in the OneClick encoder to disable resizing and use the source resolution (advanced settings), which hopefully would over-ride all that.
    I'm not certain that's the cause, but it seems pretty likely.
  6. Originally Posted by hello_hello View Post
    AVS is you script.
    From your log file:
    I choose "automated 2 pass" and it's work.
    Please give me a subtitle that i can HardSub it with MeGUI.
    In the Avisynth setting what commands should i enter?
  7. To be honest I don't understand the question. I assume you have a subtitle file you want to encode? Are you trying to encode the same subtitle into every video? You'll need to provide some detail as to what you're doing.
  8. Originally Posted by hello_hello View Post
    Yes i want do that however this problem is solved. thanks
    I want to add "AC-3" to my MeGUI
    Please give me the link and how i can ainstall it?
  9. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    AC-3 should already be there, as "FFmpeg AC-3". In Megui press "Ctrl+U" and install all the updates if you have not already.
