Is there a way to make a CDR with DVD format???
I Know you Can't burn a DVD on a CD, but I just want DVD quality... even if its only a few minutes.
Also Is there a way to make an XBox Play MPEG files other than official DVDs????
Thanks in advance for anyone with any advice!!!!![]()
yes you can. Its called miniDVD, but the xbox dont reads those to well. it show alot of little green boxes.
And sorry but all i know is it cant read VCD/SVCD/XVCD/MINIDVD BUT it does read DVD+R/W and DVD-r/w -
Thanks ozzhead42, your help was very useful...
there is 1 thing, how would I do a MiniDVD???
and Even though I can't Burn DVD's yet thanks for the tips!! -
Use a DVD authoring program to author a DVD image and then burn it on a CD.
Be aware that this will work in very very few stand-alone players.
Regards.Michael Tam
w: Morsels of Evidence -
How are you sure?
Do you actually know or do you just "think" that your player can?
There are probably less than 5 discrete models (i.e., not including re-badged units) in all the DVD players ever made that can play miniDVD.
Regards.Michael Tam
ohh, My bad, I looked at the APEX DVD Players...
They (most of them) said that they worked on the DVD Players list on the left... but I got home, and looked at my DVD's model... and it isn't on the list of compatibles... oh well...
too bad... but I like the XVCD...
Tip to people about the XVCD on the um, APEX 500w: It works great with playing an XVCD at 720x480 and 4000Kbits per sec... but some of the vids have troubles playing at that speed... its success at playing at that speed and res is marginal, but very exceptable.
I.E. it plays pretty good except for a few hiccups... and it will after a few runs through the whole disc mess up playing... but to fix that problem just turn it off on the front switch, then turn it back on. Its great...
too bad I don't have very many files that can use the resolution and bitrate...(not enough quality to warrant it.) the real problem mostly for me is that I have to use TMPGEnc 2.0 to encode the super high quality files... and its a little fussy...(wish Nero would Encode to the desired re and bitrate.) -
and my DVD player is on the DVD list and it says this about MiniDVD on the Player List:"This medis does not work but may work on some few CD-R(W) or DVD-+R(W) brands, read the Comments for more info."
Help capturing xbox 360 video when xbox is connected to monitor with vga
By laldabomb8 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2010, 02:05 -
Bookmarking topics
By Abas-Avara in forum FeedbackReplies: 6Last Post: 1st Nov 2009, 04:00 -
Finding topics or threads I responded to by ME .. [SOLVED]
By vhelp in forum FeedbackReplies: 2Last Post: 30th Oct 2009, 19:43 -
Is it possible to have more than 2 or three pages of recent topics?
By yoda313 in forum FeedbackReplies: 2Last Post: 20th Sep 2009, 09:13
