So I have the blu-ray burner installed and running on my mac pro 1,1.
I have an authored blu-ray on my hard drive I want to burn. There are 2 folders - BDMV and certificate.
I have been told to burn this so it plays on a blu-ray player I need to use UDF 2.50. I have Toast 11.04, the last version before Roxio seemingly put a governor on the burn speeds.
Does this version of Toast support that? I have the BD/HD Plug in.
Would I pick DVD Rom UDF? Isn't that 1.02? Do I do BDMV folder? If so, do I also copy over the certificate folder? Or just burn the BDMV folder using that option.
Not sure how to go about doing this. Thanks!
Burn both folders at 2.50 udf.
OK, but how do I go about doing that? Can Toast do that or do I need another program?
My main needs are this:
1. Burn BDMV/Certificate folders to blu-ray discs
2. Convert .mkv files to iso to burn to blu-ray discs
3. rip blu-ray discs
is there one program that does all this or do I need separate ones? I tried installing ts mixer and that didn't work as it kept crashing. I am on a mac pro 1,1 running 10.7.5.
Thanks!
I saw something called Data Burn + in the Apple app store. Would something like that do the above tasks?Last edited by jabbo5150; 21st Mar 2016 at 03:07.
If you opt to burn a disc in Data mode, DVD-ROM (UDF), then it will use UDF 1.02, not v2.50. Not sure what could break (if anything) if you did use this, though.
If you opt to burn a disc in Video mode, BDMV Folder, then you can add an already authored Blu-ray folder. I think this option was added just for situations like yours.
From the Toast (v14) User Guide:Toast will add a CERTIFICATE folder (with an empty BACKUP folder in it) for compatibility reasons. Or you can add (drag-and-drop) your own CERTIFICATE folder.Making a BDMV Folder Disc
You can create a Blu-ray video disc by using an already authored and valid BDMV Folder. A BDMV folder contains the media files for the Blu-ray Disc’s video and audio content and is located at the root level of the disc.
This is the best choice if you have a BDMV folder that was created by Toast or another Blu-ray Disc authoring application.
To make a BDMV folder disc:
1 From the main Toast window, click Video.
2 Choose BDMV Folder from the format selection menu.
3 Drag-and-drop your BDMV Folder in to the content area.
A summary of the information that will be copied appears in the content area.
4 Insert a blank, recordable Blu-ray disc as appropriate. Your source video will not be compressed which may require you to use a dual- layer Blu-ray disc if the video will not fit on a single-layer disc.
5 Optional: Change the destination recorder and number of copies at the bottom of the screen.
6 Click the red Burn button at the bottom right of the Toast window. Toast displays a progress bar and status information as it records your disc.
The only reason to preserve the original CERTIFICATE folder is for "Bonus View" and "BD Live" content, i.e. if the advanced extras are super important in your back-up. For backing up just the main feature, it shouldn't matter.Originally Posted by PvH on d9 -
You can use lower case letters for blu-ray titles.
Free tools on Mac: Remux BDMV folder into mp4/mkv?
By TOMillr in forum Video ConversionReplies: 5Last Post: 18th Apr 2015, 06:45 -
DVDs are burning as video_TS/audio_TS folders instead of viewable discs !!
By Cassandy in forum Newbie / General discussionsReplies: 10Last Post: 6th Aug 2014, 20:30 -
DVD burning from existing pc folder
By PhatMAK in forum Newbie / General discussionsReplies: 6Last Post: 8th Apr 2014, 14:45 -
Can't upen BDMV folder with BDInfo on Mac OS X
By naiera in forum Blu-ray RippingReplies: 9Last Post: 20th Dec 2012, 14:38 -
Adding selectable subtitles to an existing dvd with a mac
By chiappa in forum MacReplies: 5Last Post: 17th Mar 2012, 21:00
