Hi cats,
please consider C0003.MXF have a framerate different from 25fps
I need to change the framerate so that the final framerate is 25fps but also keep the same duration of the original C0003.MXF file, how can I do? thanksCode:ffmpeg.exe -r 25 -i C0003.MXF -vcodec mpeg2video -g 0 -intra -pix_fmt yuv422p -q:v 0 -flags +ildct+ilme -an output25fps.mkv
thanks now the duration is the same but video is jerky: maybe don't do the frame interpolation?Code:
ffmpeg.exe -i C0003.MXF -r 25 -vcodec mpeg2video -g 0 -intra -pix_fmt yuv422p -q:v 0 -flags +ildct+ilme -an output25fps.mkv
in this case what should I do?
Problem Changing Framerate with ffmpeg
By arshadsheikh.in in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2014, 05:00 -
MKVmerge extends total time if subtitle duration exceeds video duration
By ankutsa in forum SubtitleReplies: 1Last Post: 7th Sep 2013, 12:08 -
Audio duration change after transcoding from MP3 to MP2 or AC3
By darklock in forum AudioReplies: 3Last Post: 24th Feb 2012, 16:50 -
encoded video duration different than vob duration
By fatcharlie in forum Video ConversionReplies: 9Last Post: 4th Dec 2011, 11:04 -
FFmpeg - Change encoding rates while in-action
By ronts in forum Video Streaming DownloadingReplies: 5Last Post: 12th Aug 2011, 01:16
