Hi folks,
Just dusted off my LG LV880 VCR to try a tape. It has been used before in the past, to convert old tapes to pc without a problem. I try it today, and its stone dead. Nothing on the display what so ever. I checked the fuse in the plug, and its fine. And also the fuse in the machine, thats also good. No signs of any scorching inside the machine, for a blown component etc.
Anyone else had this problem with the LG, or other models?
Thanks.
	Sometimes fuses that look good.... aren't. If it doesn't turn on at all, it might be a fuse or a blown power supply. Or.... sometimes the loading mechanism that automatically loads and/or ejects a VHS tape gets stuck. I have a few JVC machines that do all kinds of strange things when turning them on and off.
	If the fuses are OK then the power supply is next favourite.
 The most common failures are electrolytic capacitors. Look for any that are leaking or even have 'bulging' tops, and get them replaced. You might get lucky with just doing that?
 If it's a semiconductor failure it gets more complex. Usually a complete replacement PCB is then the most cost effective answer there .... if you can still find one!
  Capturing VHS with VCR or Blu-ray/VCR combo?By SyncroScales in forum Capturing and VCRReplies: 11Last Post: 26th Dec 2014, 09:39
  Lots of Kernel-Power (Event ID:41) /Kernel-Processor-Power (Event ID:6)By Cielo in forum ComputerReplies: 0Last Post: 27th Nov 2012, 18:33
  Is this VCR a Super VHS VCR?By avz10 in forum Capturing and VCRReplies: 9Last Post: 29th Aug 2012, 01:46
  VCR/VHS playback - lines on picture...vcr alignment problem or no?By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 01:54
  Lacie Cinema: Can't power device on using remote but will power on with USBBy truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 04:03
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
