How do I denoise, deinterlace, and crop my video, all in the same app? I have 33 large DV-AVI (DVCPro) files that I need to edit ASAP. Thanks!
-Ron
Anon45Guest
Not if you need to denoise, deinterlace, and crop.
Open your video in VirtualDub, add and adjust the filters you need, select a compression coded (or not), save the result.
https://www.videohelp.com/guides?searchtext=&tools=2&madeby=&formatconversionselect=&ho...or+List+Guides -
First you want to edit. Cut unwanted footage, maybe join some files, and save the finished product.
You can do that in virtualdub by using direct stream copy mode for audio and video. Select a part you want to cut, hit the del key, check for direct stream copy, from the menu select save as avi.
To join files, just open the first file, then from the menu select append avi, select the second file, save as avi.
You might want to look at the guides here
http://www.doom9.org/capture/start.html
http://www.doom9.org/virtualdub_procedures.htm
http://www.digitalfaq.com/guides/video.htm
But you can also denoise deinterlace and crop in one step with an avisynth script opened in megui or virtualdub
QTGMC is the best deinterlacer, whatever you do you will need avisynth if you want to use it. So you might as well try to do everything in a script.Code:AVISource("C:\path\to\your avi.avi", audio=false).AssumeFPS(30000,1001) #source, no audio, fps 29.970 QTGMC(Preset="Slower", EZDenoise=1, NoisePreset="Slow") # deinterlace and denoise crop(6, 4, -6, -4) # crop, adjust to your needs but the remaining resolution should be a multiple of 4 or 8
You will also need to take the aspect ratio into account, I take care of it in x264 to keep the video anamorphic (non square pixels) but you can also resize to square pixels.
There is no easy solution, you will need to read a lot. Even a commercial product will have a learning curve.
Idea for perfect denoising
By Mephesto in forum RestorationReplies: 6Last Post: 24th Jan 2015, 08:18 -
MENCODER: how to crop 32 lines from up as virtualdub nulltransform crop?
By marcorocchini in forum Newbie / General discussionsReplies: 7Last Post: 17th Dec 2013, 16:58 -
Desinterlacing / Denoising in which order ?
By Lumbermatt in forum RestorationReplies: 20Last Post: 12th Dec 2013, 15:38 -
Spatial/Temporal Denoising
By x264 in forum Newbie / General discussionsReplies: 4Last Post: 19th Feb 2013, 13:03 -
Still have flicker after Denoising with AviSynth
By VideoFanatic in forum RestorationReplies: 279Last Post: 29th Jan 2012, 11:30
