Hello!
I am currently having a small issue with some of my videos, and I hope I can get some help here.
Sorry if It's the wrong area to post this kind of question.
I'm having a few Videos. ( mp4 ) trying to play them with the newest updated VLC player.
Now on the bottom of the VLC screen, it tells me the Video is 22:14 mins / sec long, but the Video just stops after around the half~ so 10:07
If I let VLC play the whole video, it stopps at the 10:07 mark, and goes black like the video is finished, even the progress bar on the botton just reached half of it,
Now but when I click manually into the time bar, and choose a point over the 10:07 mark, the video still plays, but the time on the bottom stops counting and I cant hear any sound anymore.
Over 20 videos are affected by that currently so Im really looking to fix it.
Would appreciate any help.
Btw : My System is strong enough to run the videos, so that won't be it.
It doens't say anything if I let the video play itself, just stops at half-way like its the normal Video ending, when its not.
And if I move manually to another time stamp which exceeded the half-way mark it gives me :
core error: Could not convert timestamp 768715366800
core error: Could not convert timestamp 768725745134
but for some reason like I mentioned its still playing - without sound. -
Have you tried anything other than just playing them? Can you demux one of the mp4 files with MyMP4Box GUI and examine the audio separately? See if the audio by itself will play smoothly through the area where the MP4 stops.
You might experiment a little and demux, then remux into MP4, or change container format and go to MKV with MKVToolnix. -
Aha!! I used the MP4Box GUI Program and found out that indeed the video is 20m long, but the audio just 10mins, that might be the reason why the Video stops, in that case. Theres nothing more I can do is it? Audio is just gone
side ways video
By StuDisney in forum Newbie / General discussionsReplies: 1Last Post: 13th Mar 2016, 13:47 -
Newbie - confused about ways to speed-up video
By WoRkZ in forum Newbie / General discussionsReplies: 0Last Post: 20th Oct 2013, 13:10 -
DVD with choices mid video - Advice on which software
By liiam in forum Authoring (DVD)Replies: 3Last Post: 25th Sep 2013, 09:19 -
Stopping huge border after stabilizing video in After Effects CS5.5
By kingmustard123 in forum EditingReplies: 0Last Post: 2nd Jul 2011, 16:38 -
Can someone recommend good low-mid-price system for video-editing/capturing
By johnharlin in forum Newbie / General discussionsReplies: 1Last Post: 17th Jun 2011, 07:08
