My wife had a coupon for downloading a movie off of some site. She gave me the movie and when I open it up in VLC, there appear to be 3 subtitle tracks; one in English, another in Korean, and a final one that I don't know what it is.
But when I open the file in mktooknix, another media player, and in subtitle extractors for windows instead, only the English track appears. And the "download subtitles" option of vlc is not selected, so I don't believe vlc is just getting them automatically.
Either way, how does one go about extracting such a sub that will only seem to show up in vlc.
Results 1 to 9 of 9
Sounds like your wife downloaded a movie with burned-in subs,if it's an illegal release of a movie then there's nothing you can do.
Again, they are separate tracks/streams. There's no burned in anything.
In VLC:
Subtitle stream 1 is English (an SRT)
Subtitle stream 2 is Korean (in EUC text encoding)
Subtitle stream 3 is some other one I didn't look into as I only care about the other two
In other players/extractors, only the English stream shows up. -
General
Unique ID : 235164590556012670704593992623067378017 (0xB0EB0D7C82D88209B2574A70A6E23161)
Complete name : ¾Ö·ÎÀÇ Áø¼ö.mkv
Format : Matroska
Format version : Version 2
File size : 812 MiB
Duration : 1h 11mn
Overall bit rate : 1 592 Kbps
Encoded date : UTC 2012-04-06 01:34:50
Writing application : mkvmerge v5.2.1 ('A Far Off Place') built on Jan 2 2012 23:21:10
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 16 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 11mn
Bit rate : 1 399 Kbps
Width : 702 pixels
Height : 438 pixels
Display aspect ratio : 2.25:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.190
Stream size : 698 MiB (86%)
Writing library : x264 core 120 r2164 da19765
Encoding settings : cabac=1 / ref=16 / deblock=1:-2:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.20:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=1399 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:0.80
Language : English
Default : Yes
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 1h 11mn
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 97.9 MiB (12%)
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Default : Yes
Forced : No -
Just a hunch - load the file into MKVMergeGui and take a look under the Attachments tab (The tab to the right of Input) Maybe there are a few jpg attachments that are confusing VLC?
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Might be Closed Captions which are not always visible to Mediainfo. In which case I would use CCextractor. Or the subtitles are teletext which is used for PAL subtitles, something I have no experience with but CCextractor may be able to deal with it.
Does anyone know how to extract subtitles from .ts?
By ALUOp in forum DVB / IPTVReplies: 48Last Post: 27th Jul 2022, 01:39 -
extract all subtitles from a mkv
By Valit in forum SubtitleReplies: 4Last Post: 10th Jan 2016, 19:10 -
Extract subtitles from avi
By Snowcrystal in forum SubtitleReplies: 11Last Post: 16th Feb 2014, 20:08 -
Extract subtitles from m4v
By thinredline in forum SubtitleReplies: 1Last Post: 22nd Sep 2012, 16:45 -
Extract subtitles from .ts
By anchonio in forum DVB / IPTVReplies: 9Last Post: 16th Apr 2011, 05:07
