Hi,
I am converting some old VHS PAL types. I capture the video using an Elgato Video Capture USB dongle. This results in an MP4 file (AVC video, AAC audio). I then transcode the file using StaxRip to reduce the file size and to crop the corners, again into an MP4 container. Most of the time, this works fine, but occasionally I loose A/V sync by a couple hundred milliseconds. I.e., the original MP4 as produced by the Elgato software plays fine, but the StaxRip-converted file does not (using VLC in both cases).
Looking at the MediaInfo output, I see "Frame rate: 25 fps". However, while it usually says "Frame rate mode: Constant", it occasionally claims "Frame rate mode: Variable" with odd minimum and maximum frame rates such as a 3.289 fps minimum or a 30000 fps maximum.
When it says "Constant", the conversion is always flawless. When it says "Variable", the conversion is sometimes fine (or maybe the A/V discrepancy is just neglegible), sometimes not, and I get a delay of up into a seconds range (IIRC the video is then always ahead of the audio).
I am attaching a StaxRip log file from a "bad" conversion.
Do you have any suggestions what I can do differently to fix these occasional glitches, or at least to further diagnose this issue?
Thank you,
Frank
I've had good luck in the past using fpsnum and fpsden with the FFvideosource. For example:
FFVideoSource("Z:\Movies\Hitchhiker-2.mp4", cachefile = "Z:\Movies\Hitchhiker-2 temp files\Hitchhiker-2.ffindex", fpsnum=25,fpsden=1) -
Dave,
indeed, that seems to work. Thank you very much for the suggestion!
It just seems a bit inconvenient, or maybe I'm doing it wrong. After loading the original file into StaxRip (which demuxes the file and creates the index file), I then create a new .avs file with the above content and re-run StaxRip using the .avs file as input. One effect is that StaxRip's crop feature does not work well: it just shows the first frame but refuses to seek. So I have to copy the crop values from the first run.
Is there maybe a way to set 25 fps as the default? I've tried adding a call to the "AssumeFPS" function as "code to add to the top of scripts", but whatever I do it complains that the parameters are invalid.
What would be the proper syntax to use, or is there another means to do that?
Thank you,
Frank -
NVENC h.265 Audio Sync Issue and fix with StaxRip - Passing knowledge along
By Newbie 332 in forum Video ConversionReplies: 0Last Post: 25th Jan 2016, 09:24 -
Sync Issues with HD-PVR 2 source after conversion
By kkiller23 in forum Video ConversionReplies: 7Last Post: 25th Sep 2014, 13:29 -
Staxrip cut file and no conversion
By JackDanielZ in forum Video ConversionReplies: 2Last Post: 16th Apr 2012, 02:37 -
DVD Conversion Lip Sync Issues
By waykins in forum DVD RippingReplies: 4Last Post: 4th Jun 2011, 09:23 -
Video/Audio out of sync after using StaxRip
By supernano in forum DVD RippingReplies: 1Last Post: 23rd May 2011, 23:30
