Hello I was just in a hit and run accident when I went to play back the files from the dash cam, I get a CODEC Error message in VLC PLAYER: Unidentified codec: VLC could not identify the audio or video codec. Does anyone have any suggestions on how I could play this file?
Results 1 to 18 of 18
hmmm I don't have a special program to view the Media Info? I looked at the attritubuties the file that does not play has an attriubute of RA the ones that will play has an attriubute of AN
hi nashfullboy....
you could try converting it with freemake....
i find that unless the video is corrupt, the supplied codecs with freemake read just about anything..... -
Model of DashCam? Maybe it has video outputs?...
Scott -
.....freemake has an editing/cutting feature used to trim clips...
....it will probably just play it without having to research, find or download any codecs....
with the added ability to re encode quickly if you need to send the footage to Mr.Plod.... -
I tried the Media Info program and I couldn't get it to work or figure out how to use it. I will try free make and get model of cam. Some files play, but as with life the one I need will not play. The camera normally BLINKS red indicating recording. But all the lights stopped. and it renammed a file LOCK I think that is the one with the wreck info.
Thanks for the information. Its a Generic "Vehicle Black BOX DVR" Mostly in Japannesse. Says Video Format AVI 1280 * 720p
When I tried Video Free Make I got an error message. But thanks for the advice and Free Make is a great program to have in my toolbox otherwise. Does Geek Squad do this work? I am willing to pay because I need to catch the person who hit me/
After installing MediaInfo you just right click on your video file and select MediaInfo.
It's probably corrupt. You might be able to restore part of it with programs like DivFix, VirtualDub, etc. -
Any help will be appreciated and rewarded. It's should be video of a Hit and Run.
Just because a file has the extension AVI doesn't mean it's an AVI file. Anybody can put any extension they want on a file. What makes an AVI file is the way data is organized within the file. Your file is not an AVI file. It is basically empty. Every byte is 0xFF (255).
Dashcams usually overwrite earlier files when the memory fills up, so if left running long enough the important file you need will be overwritten. To prevent this there's usually a G sensor in the dashcam that will "lock" the file when there's a physical bump over a set limit to prevent overwriting.
Having said that, it looks like your file is corrupted/empty anyway.
Cam Bitmap Mpeg or avi Video files be traced
By Xabache in forum Newbie / General discussionsReplies: 22Last Post: 15th Oct 2015, 02:37 -
MPEG-dash files from youtube: really variable framerate??
By flashandpan007 in forum Video Streaming DownloadingReplies: 4Last Post: 7th Jan 2014, 15:04 -
how do you play dash files?
By Gz12 in forum Video Streaming DownloadingReplies: 2Last Post: 14th Nov 2013, 19:53 -
Pixels when playing .avi / .mkv files!
By elgy in forum Software PlayingReplies: 6Last Post: 12th Aug 2013, 13:03 -
DV AVI Files Stop Playing At 4:26
By leebo in forum Software PlayingReplies: 11Last Post: 22nd Nov 2012, 18:22
