Hi
So far I have successfully converted AVCHD to 8-bit DNxHD (120M & 185M) using FFMBC 0.6.
When I try to convert to 10-bit DNxHD 185M ("-pix_fmt yuv422p10le"), nothing happens, the flag is ignored and the clip is converted to 185M 8-bit.
Assuming it is a limitation of ver. 0.6, I tried with FFMBC 0.7.2 but there I get the xvidcore.dll missing error; I have simply copied the binaries provided here and there is no such thing as xvidcore.dll
Anyone to help ?
1) how to fix the missing xvidcore.dll problem ?
2) more importantly, will that help with the 10-bit transcode (initial problem); is my assumption about the ignored 10-bit flag in 0.6 correct ?
t's several months late but to fix the xvidcore.dll problem in 0.7.2 have to install this xvid codec thing... wish they'd just remove that option...
As for 10 bit but, only in dnxhd 110
ffmbc.exe -i [File Name].mp4 -vcodec dnxhd -r [output frame rate] -faststart 1 -qmax 2 -pix_fmt yuv422p10le [File Name].mxf
why in windows 64 bit I don't see 64 bit codec with DSFmgr?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2015, 10:01 -
Do DNxHD codec is free for commercial use? Do you charge for MPEG.LA
By createstock in forum Newbie / General discussionsReplies: 0Last Post: 3rd Apr 2015, 05:57 -
Lossless (10 Bit RGB 444) and (10 Bit YUV 422) Compression Codec's
By JasonCA in forum Video ConversionReplies: 62Last Post: 26th Dec 2014, 00:40 -
Having problems converting to right codec
By Lucky Starr in forum Newbie / General discussionsReplies: 7Last Post: 24th Apr 2014, 07:55 -
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 16:14
