  1. Hi cats,
    please I wonder is ffmpeg can integrate a function like the SmoothFPS2 of avisynth?
    and also a the vfrtocfr
    thanks
  2. ffmpeg accept avisynth as source, as far as i know there is no similar video processing to SmoothFPS2 on ffmpeg. vfr2cfr is done by simple operations on frames to match cfr framerate.
  3. oh!
    Aug 2014
    India
    If smoothfps2 does interpolations, you can try the framerate filter, which does linear interpolation. You are better off with Avisynth.
  5. mulvya for kindness I have a C0003.MXF file in interlaced NTSC that I would like to convert in PAL
    this is the source
    Video
    Format : MPEG Video
    Commercial name : XDCAM HD422
    Format version : Version 2
    Format profile : 4:2:2@High
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=15
    Format settings, picture structure : Frame
    Format settings, wrapping mode : Frame
    Codec ID : 0D01030102046001-0401020201040300
    Duration : 43s 76ms
    Bit rate : 50.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 29.970 (30000/1001) fps
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.805
    Stream size : 257 MiB (83%)
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    I have try:
    ffmpeg.exe -y -r 25 -i V:\tuttiFormati\PDWf800\NTSC\C0003.MXF -vcodec rawvideo -pix_fmt uyvy422 -q:v 0 -an output25fps.avi
    but I don't know if this commandline is correct to do a frame conversion interpolation, how can I do?
    or if this commandline is correct, can I use it also for progressive source?
    thanks
  6. oh I think this commandline don't keep the same duration
  7. Just a thought. You are constantly flipping between scripts, abandoning working platforms. Ignoring old threads. You should stuck with some system and not look back. You cannot build up or update your scripts because your scripts are not modules that you can build up. All because you do not like to wait for indexing ...
    There was threads how to use ffmpeg to handle channels in MXF and make a stereo out of it and encode. But you decide getting those channels in Avisynth instead. But then you do not like Avisynh for indexing before and avoiding it. Now you choose ffmpeg to convert NTSC to PAL when Avisynth is used for that. Kind of back and forth .., you make it hard for yourself ...
  8. sorry but I'm a cat
