I record to a standalone DVD recorder and rip to my PC. Can anyone recommend a free piece of software that can trim the resulting VOB/MPEG files and apply a short fade to or from black at the beginning and end, all without re-encoding the whole thing?
(I've developed a workaround method using TMPGEnc Authoring Works, but I'd have thought there's a simpler and more elegant solution out there.)
Many thanks.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
I doubt you will find any free software that can add fade-in/out easily AND without reconverting the entire video.
But doesn't tmpgenc authoring works just reconvert at the cuts? -
It does indeed, and it's the perfect tool for what I'm trying to achieve - provided the end goal is burning to DVD. Sometimes, though, I just want the MPEG file.
My workaround at the moment is to go through Authoring Works, build a DVD folder, find the relevant VOB file, and convert back into MPEG. It works, but surely there's a more streamlined way to do this, isn't there? I mean, I literally just want to top and tail an MPEG, applying fades in and out at the same time.
Is Womble my only hope, or is there a free alternative?
SW for video trimming
By bluenite in forum Newbie / General discussionsReplies: 1Last Post: 24th Jun 2015, 07:09 -
Video stutters after trimming
By Freodon in forum EditingReplies: 120Last Post: 9th Jan 2015, 08:32 -
Help Copying and Trimming a Video
By mommiegeek in forum Newbie / General discussionsReplies: 5Last Post: 28th Apr 2014, 12:32 -
video trimming on android
By BobAchgill in forum EditingReplies: 6Last Post: 8th Apr 2014, 09:57 -
Trimming subtitles along with video
By msmirjat in forum SubtitleReplies: 2Last Post: 6th Sep 2011, 02:08
