I want to keep two dir/file hierarchies of music in sync.
So that if I add/remove/change files in tree #1, only those changes get updated in tree #2.
It doesn't need to be realtime.
rsync works perfectly for trees 1 & 2 simply containing the same files/formats. E.g., an ogg tree -> ogg tree sync.
In this case, though, tree 2 contains an audio-format conversion of tree 1.
I.e., all the dir/file names & hierarchy are the same, except that every tree 1 .ogg file exists as its converted .mp3 analogue in tree 2.
(How) can rsync be used to keep these 2 different trees in sync, detecting changes in tree 1, then converting-then-rsyncing only those files/folders?
Or, is rsync not the best tool here?
Results 1 to 1 of 1
AVStoDVD audio out of sync on converted mkv
By whammoed in forum DVD RippingReplies: 23Last Post: 11th Jul 2014, 11:00 -
Enable audio stream switch only default one is displayed, 2nd audio missing
By Fproviders in forum Video ConversionReplies: 5Last Post: 2nd Nov 2012, 18:25 -
Audio Gradually Drifts Out of Sync in Converted DV files
By mirbramo94 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 27Last Post: 23rd Sep 2012, 15:14 -
Handbrake converted videos out of audio sync on WD TV
By cinesimon in forum Video ConversionReplies: 2Last Post: 2nd Jul 2012, 23:15 -
Converted video (mp4): audio out of sync
By darknezx in forum Video ConversionReplies: 4Last Post: 22nd Mar 2011, 03:25
