I have some AVI files I need to browse and/or convert. The source was a CCTV system, about 2001. The codec used is ADV1. I have both Windows 7 and Ubuntu machines I can use. Any idea how to proceed? I tried one downloadable codec file and it produced only mangled video images. I think the problem may be it was intended for older operating systems, like Win97, etc.
Track down the cctv system used, then if the manufacturer has a special player. Install the player (may need vm) and then do a screen recording. Most cctv systems are proprietary and likely encrypted.
Scott -
It is/was very common for cctv manufacturers to use standard codecs but with a different fourcc to disguise it. You might be able to change the fourcc and a standard decoder. Fourcc.com doesn't have much information about ADV1:
http://www.fourcc.org/adv1/
This might be the codec:
http://www.codeccodecs.com/codec-adv1-loronix-wavelet-t236.html
I doubt it's really a wavelet based codec though -- not from 15 years ago.
A device from 15 years ago may have used Xvid or Microsoft's MP42 or other codecs. Upload a sample and someone here will try a few things.Last edited by jagabo; 13th Mar 2016 at 19:29.
Not that common. They'd often take a common process (e.g. h.261, h.263) and tweak just a few things so that it wouldn't be natively compatible (might be viewable, but in a garbled way).
I did a LOT of forensic work back then (10-15 years ago), and the MAJORITY of those I encountered were purposefully & confoundingly proprietary.
AVI video codec
By moera in forum Newbie / General discussionsReplies: 4Last Post: 28th Jan 2016, 07:58 -
Guidance for converting to AVI video...
By patel_d21 in forum Video ConversionReplies: 10Last Post: 21st Apr 2014, 14:23 -
Converting video to AVI MPEG4
By jaspervanzyl in forum Video ConversionReplies: 5Last Post: 7th May 2013, 10:57 -
Converting video - mpgv to avi
By In need of help in forum Newbie / General discussionsReplies: 2Last Post: 9th Oct 2012, 11:50 -
Help converting with mkv2vob: Error is Unsupported Video Codec
By sweetnessuk in forum Video ConversionReplies: 7Last Post: 17th Jun 2012, 06:08
