  1. HI C*T(s):
    please I need help
    I try to load in avisynth this C0060.MXF
    Generale
    Complete name : C:\Users\Administrator\Desktop\Nuova cartella\C0060.MXF
    Format : MXF
    Commercial name : XDCAM HD422
    Format version : 1.2
    Format profile : OP-1a
    Format settings : Closed / Complete
    File size : 86,1MiB
    Duration : 12s 0ms
    Overall bit rate : 60,2 Mbps
    Encoded date : 2014-06-21 20:10:08.000
    Writing application : SONY Opt 1.22
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : 4:2:2@High
    Format settings, BVOP : Si
    Format settings, Matrix : Personalizzato
    Format settings, GOP : M=3, N=12
    Format settings, picture structure : Frame
    Format settings, wrapping mode : Frame
    Codec ID : 0D01030102046001-0401020201040300
    Duration : 12s 0ms
    Bit rate : 50,0 Mbps
    Width : 1.920 pixel
    Height : 1.080 pixel
    Display aspect ratio : 16:9
    Frame rate : 25,000 fps
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 8 bit
    Scan type : Interlacciato
    Scan order : Top field first
    Compression mode : Con perdita
    Bits/(Pixel*Frame) : 0.965
    Stream size : 71,5MiB (83%)
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio #1
    Format : PCM
    Format settings, Endianness : Little
    Format settings, wrapping mode : Frame (AES)
    Codec ID : 0D01030102060300
    Duration : 12s 0ms
    Bit rate mode : Costante
    Bit rate : 1.152 Kbps
    Channel(s) : 1 canale
    Sampling rate : 48,0 KHz
    Frame rate : 25,000 fps (1920 spf)
    Bit depth : 24 bit
    Stream size : 1,65MiB (2%)
    Audio #2
    Format : PCM
    Duration : 12s 0ms
    Bit depth : 24 bit
    Audio #3
    Format : PCM
    Duration : 12s 0ms
    Bit depth : 24 bit
    Audio #4
    Format : PCM
    Duration : 12s 0ms
    Bit depth : 24 bit
    Audio #5
    Format : PCM
    Duration : 12s 0ms
    Bit depth : 24 bit
    Audio #6
    Format : PCM
    Duration : 12s 0ms
    Bit depth : 24 bit
    Audio #7
    Format : PCM
    Duration : 12s 0ms
    Bit depth : 24 bit
    Audio #8
    Format : PCM
    Duration : 12s 0ms
    Bit depth : 24 bit
    Altri #1
    Type : Time code
    Format : MXF TC
    Time code of first frame : 01:02:34:00
    Time code settings : Material Package
    Time code, striped : Si
    Altri #2
    Type : Time code
    Format : MXF TC
    Time code settings : Source Package
    Altri #3
    Type : Time code
    Format : SMPTE TC
    Muxing mode : SDTI
    This is my script:
    SetMemoryMax(16)
    LoadPlugin("v:\automazioneclip\avisynth\plugins\LSMASHSource.dll")
    videofile1 = LWLibavVideoSource("C:\Users\Administrator\Desktop\Nuova cartella\C0060.MXF" )
    audiofile1 = LWLibavAudioSource("C:\Users\Administrator\Desktop\Nuova cartella\C0060.MXF" )
    left1 = GetChannel(audiofile1, 1)
    right1 = GetChannel(audiofile1, 2)
    both1=mergechannels(left1, right1)
    audiodub(videofile1,both1)
    but I get this error in the audio section:
    what could it be?
    thanks
  2. The problem is that your source file does not have a single audio track with multiple channels but instead multiple mono tracks. LWLibavAudioSource loads the first (mono) track by default so there is no second channel for GetChannel() to access. You have to make two calls to LWLibavAudioSource() to read two tracks instead of using GetChannel(). Read the README that is included in LWLibavAudioSource() for info on how to select a specific audio track.
  3. Oh my cat: it's so complicated
  4. One thing I should mention: I assume you want to convert 7.1 to stereo audio? You cannot just pick the front left and front right channels (here: tracks). That way you would lose e.g. the center channel where all the talking happens. You need to load all (except LFE?) tracks/channels and make a downmix to stereo from that.
    http://forum.doom9.org/showthread.php?p=1303150#post1303150
  5. my target is getting a simple stereo L+R
    audio channel1+audiochannel2 of the camera
