  1. Hi,
    I've some avi sources and I want to convert all to h264 with 60% of the original bitrate of each file.
    Is It possible to do with Avanti and Avisynth?
    Nope. I haven't seen any converter where you can adjust the % of original bitrate.
    You could always try use a constant quality/quantizer variable bitrate with a value around 20-30 and see if it reduce the bitrate enough.
    (If they all have same bitrate can you of course set the bitrate manually.)
  3. And with FFmpeg script? Has any chance?
    Nope.
