Using Potplayer for many years with minimal problems. Now all the sudden some videos are coming up with a complete green screen. The two files I noticed are AVI and FLV (BTW..other AVI and FLV files are playing fine). These have played fine before. Before I start hitting buttons and really fouling things up even more does anyone have suggestions?
I have not changed anything (that I know of) in Potplayer, or my computer.
Thanks in advance.
Sorry, I am new to this. I have downloaded and installed the latest version, and looked at the info for one of the vids. So what's next?Mediainfo of files?
I did try the AVI file in Windows Media Player and it played, no problem.
[Attachment 36180 - Click to enlarge]
If you need more info I will get it from any of the menu items on the lower right.
Thanks again. -
Have you tried change Video->Video renderer in PotPlayer and see if it make any difference?
Or else try install ffdshow or lav filters and see if it helps. They are easy to uninstall also(compared to HUGE codec packs)
How do you get rid of this screen on PotPlayer?
By MetaNemesis in forum Software PlayingReplies: 17Last Post: 18th Jun 2016, 18:57 -
PotPlayer: Can't Cycle AR in Full Screen
By Michael Linder in forum Software PlayingReplies: 1Last Post: 29th Jun 2015, 03:45 -
PotPlayer screen goes black... and goes back (need help)
By yro in forum Software PlayingReplies: 1Last Post: 27th Aug 2014, 19:16 -
Green Screen and Screen Flickers On And Off
By Teac23 in forum ComputerReplies: 2Last Post: 9th Jul 2014, 11:57 -
potplayer vmr 9 renderer and lock screen
By muffinman123 in forum Software PlayingReplies: 0Last Post: 10th May 2014, 19:07
