I noticed a TV series had both 16bit and 24bit audio on the same disc. Any idea why that would be? Why not just have 24bit audio for everything?
	1. How do you know for sure those bitdepths?
 2. Maybe they changed production/distribution companies? Happens alot.
 3. Does it really matter? If done correctly, 16bit is still quite good enough for distributing to the vast majority of consumers.
 Certainly not worth fretting about or spending time and effort trying to "fix".
	Yes but MI only reports on headers not actually testing streams, and has been known to misreport.
 Particularly WRT compressed formats that don't rely on an inherent bitdepth.
	Maybe the disc's "producer" is indeed incompetent, or has no skills with detail on the format, and only a "producer" because they are a nephew/niece/cousin/fill-in-the-blank of someone high up in the company. Happens alot too. I hate VHS. I always did.
	It might depend on the format. Some are compulsory for Bluray while some are optional. The disc might have an older format to cover the "compulsory" type and a newer format for the golden ear brigade. https://en.wikipedia.org/wiki/Blu-ray#Audio
 Also.... lossy formats such as the older AC3 and DTS, don't actually have a fixed bitdepth. They may store info regarding the bit depth of the source from which they were encoded, or the bit depth that's supposed to be used for decoding them, but that's what MediaInfo would be reporting for the lossy formats. Not the bitdepth of the file itself.
  Convert 24bit/48kHz wav to 16bit/44.1kHz using SoXBy Keyser in forum AudioReplies: 15Last Post: 16th Sep 2014, 07:51
  Going from 24bit 5.1 DTS to 16bit 44.1KHz 2-ch CDBy carlmart in forum AudioReplies: 5Last Post: 3rd Dec 2013, 10:19
  Did they ever make a bluray disc changer or a bluray/vhs combo?By yoda313 in forum Off topicReplies: 4Last Post: 28th Mar 2013, 17:03
  How to shrink a 50GB-BLURAY-movie to fit on a 25GB-BLURAY disc ?By kulmagen in forum DVD RippingReplies: 31Last Post: 1st Feb 2012, 14:39
  Bluray DTS 24bit vs 16bit w/AC3FilterBy Tony Jenkins in forum AudioReplies: 2Last Post: 4th May 2011, 13:07
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
