  1. I've collected quite a few videos from a high speed camera at 10,000 FPS, from the camera the files are saved as uncompressed .mov files. However I need to upload these to ImageJ as an uncompressed .avi file in order to go through the video frame by frame. I guess I could convert these to .avi files in h.624 codec and then decompress but believe I will lose frames this way?! Does anyone have any suggestions?I am in no way at all tech savvy!
    Many thanks!
  2. Why not just install Quicktime? Then you can play your files as-is. If you go to Quicktime Pro ($30) you can export as sequential jpeg, png or other formats that ImageJ supports.
  3. You can probably batch convert with ffmpeg
    But is that what you really want ? I guess the question is why are you using ImageJ ? There are other better options to view videos frame by frame
    Aug 2014
    India
    You don't need to use H.264 as an intermediate format. You can use FFmpeg to convert to uncompressed AVI. You won't lose any quality unless there's a colorspace conversion or a change in pixel format or chroma sampling scheme. What does mediainfo say about these MOVs?
  5. Member Cornucopia's Avatar
    QT pro can export as Uncompressed AVI also, so one-stop shop.
  6. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Virtualdub via ffmpeg input driver should also do it and it is free.
  7. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    ^+1 for Virtualdub
