Hey ya'll,
I have a bunch of aac I demuxed from some mp4 videos, and I want to get them over to m4a eventually to throw them into picard and get all my metadata on there and have them compatible with my devices. I have YAMB and Avanti but Avanti doesn't seem to have this functionality built in, and YAMB throws errors every time I try to mux the aac to m4a or mp4 (although really oddly sometimes I get a file output that sounds ok even when it says muxing failed). I was able to batch demux with Avanti very easily and smoothly but I'm stumped for the next step.
It is my understanding that this should be a trivial task with YAMB. Am I an idiot?
Perhaps this may help:
https://ffmpeg.org/ffmpeg-bitstream-filters.html#aac_005fadtstoasc -
Ah, thanks. I'm not too good with command lining, which is why I'm using front end GUIs for everything. I ended up with this:
but I can't figure out how to relocate processed files to a different directory and change the file extension rather than just putting .mp4 after .aac. All my files are *.aac.mp4 now, hah.Code:set thisdir=%1 For /R %thisdir% %%J IN (*.aac) do ( "path_to_ffmpeg\bin\ffmpeg.exe" -v error -i "%%J" -acodec copy -bsf:a aac_adtstoasc -vn "%%J".mp4 ) pause
.aac to .m4a.. possible?
By romi7519 in forum AudioReplies: 35Last Post: 14th Dec 2018, 06:45 -
change m4a to aac container
By jamespoo in forum MediaReplies: 11Last Post: 7th Feb 2017, 23:15 -
aac to m4a
By angelroj7 in forum AudioReplies: 4Last Post: 13th Dec 2013, 11:02 -
Opening iTunes AAC (m4a) files in Sony Vegas
By Ronaldinho in forum Newbie / General discussionsReplies: 0Last Post: 26th Jun 2013, 00:20 -
Nero 9 no longer burns AAC/MP4/M4A
By Poppa_Meth in forum ComputerReplies: 8Last Post: 24th Mar 2013, 12:01
