Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
Results 1 to 9 of 9
    Jun 2007
    Kuwait
    Hello,
    I have a video which has a big problem with Fieldblending/Frameblending so i try to fix it using Srestore
    but i can't because it too strong or may i have use it in wrong way. Now i need some help or suggestion
    to fix this problem i will post 3 scene as an image because i can't post the video here.
    scene 01:
    scene 02:
    scene 03:
  2. You need to provide a sample of the source.
    Jun 2007
    Kuwait
    I can't because it is a dvd from ebay and it is converted from Japan VHS to DVD so it is not original source
  4. Upload a sample of what you are starting with. If that's DVD use a program like DgIndex or Mpg2cut2 to snip out a 10 second sample that shows the problem.
    And what exactly are the images you posted? Are you seeing as many as 5 duplicate blended frames in a row in the source? Or is that after you (bob) deinterlaced somehow?
    Jun 2007
    Kuwait
    There is a lot of Fieldblending/Frameblending in the video itself. I'm not sure if it only Fieldblending/Frameblending
    or there is also deinterlaced too.
    https://www.dropbox.com/s/o5ws837kivr8mlb/VTS_01_1.demuxed.m2v?dl=0
  6. The underlying frame rate of that video is around 7.5 fps. The blended frames aren't blended with an adjacent unblended frame, but rather a blend of two other unique frames of the original source. I believe there are a lot of missing frames too. I don't see any way of removing/repairing the blended frames leaving smooth motion.
    Jun 2007
    Kuwait
    Thanks jagabo so that is the main problem there is some missing frames which cause it.
  8. Hehe, the main problem is the idiot that ruined it. As jagabo said, it's hopeless.
    Jun 2007
    Kuwait
    Hello,
    I have asked a friend to convert my own VHS Arabic for the same anime and i want a help to clean it a little so i think it need more than just use denoiser and sharpen filter ? I need more explanation about the problems the video have and how to fix it. please ?
    10 sec video ( 7MB ):
    https://www.dropbox.com/s/y1v9qysyw7yzkwr/Alramia.44.2.demuxed.m2v?dl=0
    1 min video ( 42MB ):
    https://www.dropbox.com/s/cjd6sgama2ovxnr/Alramia.44.demuxed.m2v?dl=0
