Hi
i don't know if the correct term is split
for split i mean https://youtu.be/u7VTkceSsEw?t=8s
or even more complex
can not find a video on youtube
thanks
Did you misspell it when searching, too?
https://www.youtube.com/results?search_query=how+to+create+split+screen+videos+ -
The actual steps will differ with the app, so you need to tell us what you're using if you want anything beyond generalities.
Otherwise:
1. Add 2 clips
2a. Put them in the same track and apply a non-moving transition effect.
or
2b. Put them each in their own track, one above the other, and apply complementary crops.
or
2c. Put a splitscreen effect in a track and use the 2 clips as the sources.
or...
Scott -
hi Scott
thanks , i will try today!
but i guess that with crop i can't have oblique crops , can i ?
should i download the diagonal matte png ?
https://youtu.be/hkIxT9XHRfA?t=2m15s
cheersLast edited by rama; 12th Mar 2016 at 02:28.
Think of a Matte as a book and the pages are the layers.
The whole process is called compositing. You are aggregating curated content.Last edited by budwzr; 13th Mar 2016 at 09:49.
[DVD LAB PRO] Help create a "RESUMEN PLAY" of a film
By kirous in forum Newbie / General discussionsReplies: 14Last Post: 22nd Aug 2015, 23:18 -
How to create a "neutral sequence" at the beginning of a video track ?
By csosog in forum EditingReplies: 0Last Post: 7th Aug 2015, 08:24 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 08:21 -
How to create a "rain" of logos ? ( particle generator ? )
By PeteV in forum Newbie / General discussionsReplies: 6Last Post: 9th Sep 2014, 18:32 -
Batch create simple ("DirectShowSource") .AVS files?
By Asterra in forum Newbie / General discussionsReplies: 8Last Post: 10th May 2011, 01:46
